Thread: Tie rod ends
Results 1 to 17 of 17
  1. #1 Tie rod ends
    SE Level Member GranPri's Avatar
    Alabam
    I just learned today that GM put tie rods ends on my Grand Prix with no grease fittings and at 67k miles the inevitable has happened. What the heck were they thinking?
    A nice little video to help if you must replace those tie rod ends.
    YouTube - DIY Outer Tie Rod End Replacement
    I will be doing this soon.
  2. #2 Re: Tie rod ends
    Michigain
    A lot of good reason behind no grease fittings. 90% of new car's today don't have them. You get a lot of people that will just pump the boot's up intill they tear when that happens it really kill's the life of the tie rod, ball joint inless your wanting to crawl under your car every couple of week's to flush them with more grease to push all the dirt and road grim out of them from the tore boot. It's pretty common to see a non serviceable item like your talking about go 100,00 miles with out any issues.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
  3. #3 Re: Tie rod ends
    Alabam
    That sounds logical but after 5 decades and ownership of many cars including a 78 Camaro I rebuilt, replaced several trans, got dozens of tickets in and drove through hell and high water I would have to disagree with you on this. That maybe what GM claims to remove responsibility for a bad decision.
    I have never been good at keeping a perfect maintenance schedule. But I did change my oil regularly and I would hit the grease fittings maybe once a year or maybe not that often. I did open the boots at times by putting too much grease in when I did but after many years and many cars I never ever had to replace anything in my chasis other than shocks. Never had a tie rod end to go bad.
    It appears the thick grease wears down in the working area and/or squeezes out but remains thick and held in place by the boot good enough to keep sludge out of the joint and an occasional squirt to the fittings does just fine. Without a grease fitting it's only a matter of time(67k in my case) before they(both) are worn out and wobbling like a duck.
    A Poor decision by GM
    06 Grand Prix
  4. #4 Re: Tie rod ends
    I live here. TLSheff's Avatar
    They did it as a means to keep shady "techs" from causing problems, and/or lack of maintenance causing the problem. If the new ones fail, they fail. Its a mechanical fail, not somebody that didn't know what they were doing or someones negligence to the vehicle. They are meant for 100k+ so usually they don't. I work parts in a GM dealership, rarely do I see the new tie rods come in messed up under 100k, if at all... the older ones with grease valves, those we replace often (then again, the are in older vehicles with higher mileage). Its a toss up, like anything mechanical, it will break eventually regardless.
    People today simply don't have the time, or take it to make sure the car that gets them back and forth is properly maintained. In reality too often most people don't even know anything about a vehicle but the radio, seat adjustments and how to work the pedals and wheel. They go to "grease and go" because they get the oil changed in 10 mins or its free crap and that give them more time to sip the latte at the starbucks. But what happens when the vehicle breaks down, WAAHHHH!!! woe is me!!!
  5. #5 Re: Tie rod ends
    Michigain
    With out a doubt going to agree with TLSheff on this one, after myself being a gm diesel tech for a number of years he's pretty much nailed this topic on the head and has explained it better then I would of.
  6. #6 Re: Tie rod ends
    Please try to pay attention to where you're posting.
    Its been moved.
    Thanks.
  7. #7 Re: Tie rod ends
    Michigan
    I agree that since most people that have had their oil changed will sometimes do it themselves and not even look at the grease zerks when they did so. Working in a GM dealership I saw that quite a bit. However, when I worked at the GM Proving Ground in Milford I found out that the zerks were eliminated simply because parts without the zerks were way cheaper. When you get replacement parts from Auto Z, NAPA, etc. they will have zerks on them if they have a lifetime warranty.
  8. #8 Re: Tie rod ends
    Quote Originally Posted by GrandPrixChris View Post
    Not always true.
    But this is part of the appeal to the moog rear sway links.
    That and they are larger.
  9. #9 Re: Tie rod ends
    Michigan
    Not always true.
    Yeah, some Chinese parts my have zerks on them.
  10. #10 Re: Tie rod ends
    Charles City, IA
    FYI I have 154k on my stock tierods. No play at all.
    SMGPFC Two Nipple General
  11. #11 Re: Tie rod ends
    Alabam
    Thanks for your replies guys.
    I used to always change my oil. But with the grandPrix I've alway took it somewhere. Getting lazy in my age.
    These oil change places always grease my car and check everything.
    I noticed the Kendal synthetic blend used by Firestone makes my valves tick while cold. It appears my 3.8 GP don't like synthetic blends.
    06 Grand Prix
  12. #12 Re: Tie rod ends
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I replaced the right side one on my 05 at 45k and the left one is shot at 57K.
  13. #13 Re: Tie rod ends
    Michigan
    Quote Originally Posted by Vegas~Blown View Post
    I replaced RH tie rod on my '91 at 160k miles and both on my '98 at 189k miles, but I consider myself lucky that they lasted that long because this state is so pot hole ridden in the cities. The '05 and '06 are still solid so far.
  14. #14 Re: Tie rod ends
    Alabam
    You must be a huge fan of Granprix to own 4 so far??
    What will you do now that Pontiac is gone?
    06 Grand Prix
  15. #15 Re: Tie rod ends
    Michigan
    Quote Originally Posted by GranPri View Post
    I don't know. If I hit the lottery I will get a Camaro and have it made to look like a Firebird, there are some out there but I'm not too crazy about there style. Buy any existing large-mid size car that GM makes and make it a GP, if I was rich. Main thing is to keep working on the vehicles I have and keep them going.
    The '90 has 345k miles now and the '98 has 238k miles, ordered/bought the '98 new.
  16. #16 Re: Tie rod ends
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    190K on non greaseable tie rod ends, sway bar links, and ball joints. just now replacing them. must not have been that bad of a decision.......
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  17. #17 Re: Tie rod ends
    Alabam
    It was a bad decision with my GP.
    Tie rod ends replacement is a breeze tho
    Changed brake pads and tie rod ends in just a few minutes..
    06 Grand Prix
  1. Interchanging Bottom Ends?
    By V6Junker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:33 PM
  2. Looking for evaporator tubing ends at TB
    By nlinesk8s in forum General Tech Discussion
    Last Post: 01-11-2009, 05:43 AM
  3. How hard is it to replace tie rod ends?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 10:55 PM
  4. Front ends squeaks when steering...
    By brycemassey in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 06:15 PM
