Personally...I'd rather use a brake type flare/bubble connection. It stands up to the pressure rating you need whereas a compression fitting isn't rated for it.
true, but ive had them on every line possible over the years, never a failure. brake, trans, fuel. i got 2 on my car now for a brake line repair.
for 2 bucks each, its worth it to me.
But, to emulate that S-curve I'll need to use a nylon plasticy line, no? Which would connect to a connector attached to the filter, and a compression fitting wherever I cut off the line?
if you cant bend the metal line if its not soft enough to do by hand, you use a small metal pipe bender. small one is maybe 10 bucks or so. but a pvc tube or round pipe will also work. as long as your not making the turn to tight.
If you bought NiCopp line..you could bend it around a soda can with your pinky finger
*head explodes from options and opinions*
I'll go to Hedahls after class and see what they have that I can get right now to repair it, at least for now.
I'm a college student, so I need to be cheap, lol.
Yeah, my brother did the same thing on his 90s Grand Am a number of years back and it held fine. I think I'll just watch it closely for a couple weeks and if it seems to be holding good I'll leave it alone - if it doesn't hold right I'll do something with compression fittings and such.
Thanks for all the help and input guys, really appreciate it!
A little late but in case you need the info for the future.
http://www.grandprixforums.net/threa...25#post1379825
Thanks, bookmarked for future use!
