Thread: Fuel Filter & lines - what to do?
Results 1 to 20 of 35
  1. #1 Fuel Filter & lines - what to do?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, due to problems told of (here: http://www.grandprixforums.net/threa...or-02-1999-GTP ) I figured I'd get a fuel filter since it's a good thing to replace and I doubt the one on my car had ever been replaced. We started to wrench a little on the old one and the line leading to it started leaking like crazy. So, we just cut it off since it's all rusted and leaky.
    What is a good solution to this? Will a redneck hose-clamping and some rubber hose work between a connector on the filter and where the piping isn't rusted? (I don't like that idea, but my Dad does, lol) Is there a good fitting/piping I cam get in there to hook up to the new filter? Should I do some other system with a different style filter, should I replace the whole line (what would that take and cost?), ect.?
    Just looking for the equilibrium of best (long lasting - I'll be putting around 7k miles from now till spring driving to college) and cheapest way to fix this.
    Any suggestions appreciated!
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Fuel Filter & lines - what to do?
    dorman sells a repair kit for that part. not sure if they include a compression fitting or something.
    or you can buy line with a line nut already, cut to fit and use a compression fitting.
  3. #3 Re: Fuel Filter & lines - what to do?
    Jun 2015
    @Scotty,
    http://www.autopartswarehouse.com/se...0&addfitment=1
    This: http://www.autopartswarehouse.com/sk.../RB800059.html ?
    How does that line emulate the S-curve though, doesn't the 'fix' line need to be vinyl or something so it can flex and fit into the spot of the old line?
    Yeah, couldn't find our small one.
    Okay.
    @SG,
    Okay.
    Used: http://www.milwaukeetool.com/power-t...rdless/2620-22 I was scared about starting the car on fire. :P
  4. #4 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    Get this and use the impala filter. You'll never have to worry about the nut again.
    http://www.amazon.com/Dorman-800-054.../dp/B000CIR1NY
    Sent from my LG G3
  5. #5 Re: Fuel Filter & lines - what to do?
    Jun 2015
    @Scotty,
    This?
    http://www.dormanproducts.com/p-3312...ine&origin=YMM
    http://www.amazon.com/Dorman-800-059.../dp/B000CIR1O8
    Would I just get a nylon line to emulate the S-curve then with a line nut, plus compression fitting?
    @HOR,
    What year Impala filter, or part number?
  6. #6 Re: Fuel Filter & lines - what to do?
    no this kit http://www.autopartswarehouse.com/sh...ick/regal.html just search it for your car, thats a regal search.
  7. #7 Re: Fuel Filter & lines - what to do?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by Kaiser Pontiac View Post
    I don't know how much pressure is in those lines, but it might. Maybe if you clamp it on really good. And how did you cut the line off? I keep imagining you using a little Dremel thing with sparks flying everywhere and your car starting on fire lol. But obviously it didn't.
  8. #8 Re: Fuel Filter & lines - what to do?
    Jun 2015
    I'm thinking about doing a clamped hose, but I just want to avoid possible issues later and want it to work good and not have to be messed with for a long while - if ever, since it's my only vehicle and all.
  9. #9 Re: Fuel Filter & lines - what to do?
    Apr 2015
    I'm thinking taking a rubber hose and shoving it like 6 inches up the fuel line so it's on there long enough it can't come off easily and then clamping it on with everything you've got. I don't think there is too much pressure that it'll just blow right off. But then again, that might not work. But I would try that first before you start attaching lines and stuff.
  10. #10 Re: Fuel Filter & lines - what to do?
    hacksaw is the slow safe way.
    a compression fitting will hold it. sand the old pipe clean of rust or the ring will have issues going on.
  11. #11 Re: Fuel Filter & lines - what to do?
    Apr 2015
    I feel I'm gonna have to do what OP did. Mine looks identical with the rust and stuff. But I don't know what line fittings and stuff are so a clamped hose is what I'm hoping will work.
  12. #12 Re: Fuel Filter & lines - what to do?
    Jun 2015
    Yeah, I suppose try that and watch it to see what it looks like... I'll get a fitting to go into the filter tomorrow from Hedals and some rubber hose and see what I can Jimmy-up.
  13. #13 Re: Fuel Filter & lines - what to do?
    Apr 2015
    I'm afraid I'll have to cut mine too because my coupler has just as much rust as yours did.
  14. #14 Re: Fuel Filter & lines - what to do?
    you can bend the new line from the kit, aka make it fit.
  15. #15 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    Wow Scott. Why refer him to the original set up when you can provide a better alternative?
    Sent from my LG G3
  16. #16 Re: Fuel Filter & lines - what to do?
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    why would you want to mate a plastic line to a metal one? not my car.
  17. #17 Re: Fuel Filter & lines - what to do?
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    What is a compression fitting?
  18. #18 Re: Fuel Filter & lines - what to do?
    Quote Originally Posted by SubwayGirl View Post
    It's something you can google and know more about than we can explain in laymans terms. Short answer..it's a type of connection.
  19. #19 Re: Fuel Filter & lines - what to do?
    Jun 2015
    @HOR,
    What year/part # Impala filter would I need?
    I can always Jimmy-up a hose to that - and if it doesn't work I can just get http://www.amazon.com/Dorman-800-054...iglink25855-20 . I have to buy a new filter anyways, this way if the hose doesn't work I can still go to a better solution than the original set-up without buying another filter.
  20. #20 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    @HOR,
    I don't remember what year. IIRC it was an Impala. I'll look when I get home
    Sent from my LG G3
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. Brake Leak Near Fuel Filter, Proportioning Valves and Lines...
    By Primal in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2013, 11:35 AM
  3. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  4. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
