Thread: Fuel Filter & lines - what to do?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Fuel Filter & lines - what to do?
    Personally...I'd rather use a brake type flare/bubble connection. It stands up to the pressure rating you need whereas a compression fitting isn't rated for it.
  2. #22 Re: Fuel Filter & lines - what to do?
    true, but ive had them on every line possible over the years, never a failure. brake, trans, fuel. i got 2 on my car now for a brake line repair.
    for 2 bucks each, its worth it to me.
  3. #23 Re: Fuel Filter & lines - what to do?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    But, to emulate that S-curve I'll need to use a nylon plasticy line, no? Which would connect to a connector attached to the filter, and a compression fitting wherever I cut off the line?
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  4. #24 Re: Fuel Filter & lines - what to do?
    if you cant bend the metal line if its not soft enough to do by hand, you use a small metal pipe bender. small one is maybe 10 bucks or so. but a pvc tube or round pipe will also work. as long as your not making the turn to tight.
  5. #25 Re: Fuel Filter & lines - what to do?
    If you bought NiCopp line..you could bend it around a soda can with your pinky finger
  6. #26 Re: Fuel Filter & lines - what to do?
    Jun 2015
    *head explodes from options and opinions*
    I'll go to Hedahls after class and see what they have that I can get right now to repair it, at least for now.
  7. #27 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    Quote Originally Posted by Kaiser Pontiac View Post
    @HOR,
    What year/part # Impala filter would I need?
    I can always Jimmy-up a hose to that - and if it doesn't work I can just get http://www.amazon.com/Dorman-800-054...iglink25855-20 . I have to buy a new filter anyways, this way if the hose doesn't work I can still go to a better solution than the original set-up without buying another filter.
    I don't remember what year. IIRC it was an Impala. I'll look when I get home
    Sent from my LG G3
  8. #28 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    Quote Originally Posted by ScottyDoggs View Post
    Well not gonna lie but you're cheap as hell....lol
    Sent from my LG G3
  9. #29 Re: Fuel Filter & lines - what to do?
    Jun 2015
    I'm a college student, so I need to be cheap, lol.
  10. #30 Re: Fuel Filter & lines - what to do?
    Jun 2015
    We'll see how this works:
  11. #31 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    Had to do the same thing on a Chevy 1500 a few years ago. Owner was being a cheap ass but the end result was good. Never had an issue and future fuel filter changes were easy as hell.
    Sent from my LG G3
  12. #32 Re: Fuel Filter & lines - what to do?
    Jul 2010
    Coquitlam,BC,Canada
    That will probably hold for years; with the sharp bend in the hose, it can't move anywhere.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #33 Re: Fuel Filter & lines - what to do?
    Jun 2015
    Yeah, my brother did the same thing on his 90s Grand Am a number of years back and it held fine. I think I'll just watch it closely for a couple weeks and if it seems to be holding good I'll leave it alone - if it doesn't hold right I'll do something with compression fittings and such.
    Thanks for all the help and input guys, really appreciate it!
  14. #34 Re: Fuel Filter & lines - what to do?
    Enfield, CT
    A little late but in case you need the info for the future.
    http://www.grandprixforums.net/threa...25#post1379825
  15. #35 Re: Fuel Filter & lines - what to do?
    Jun 2015
    Thanks, bookmarked for future use!
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. Brake Leak Near Fuel Filter, Proportioning Valves and Lines...
    By Primal in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2013, 11:35 AM
  3. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  4. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
