Thread: Help me understand rockers
Results 1 to 6 of 6
  1. #1 Help me understand rockers
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I am trying to research all about rockers because I am interested in putting some in my 04 grand prix. Currently I am top swapped with stock gtp L32 heads. Since I have stock heads, I am only able to get away with 1.9 rockers correct? Also if I install them I would need to get heavier springs to go with it, 90# is what I believe I read. Is that all I would need? Maybe new retainers? Tuning would be needed I assume. I want to know as much as I can before I pull the trigger. Thanks in advance!
  2. #2 Re: Help me understand rockers
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Xorbex (another member here) had trouble installing 1.9's on his 04+ gtp. I think its a clearance issue with something, but i'm pretty sure there could be issues. Maybe just with the Harland sharp ones, not sure, but my point was be cautious.
    And yes, if you do get new rockers you should get heavier springs, new retainers, locks (you will lose some) and valve seals.
    BUT.
    Just go Cam.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: Help me understand rockers
    Mar 2014
    Tucson
    I though it had something to do with the push rods rubbing on the casting of the series 3 heads?
    It was a while ago but DarkHorizon wrote a pretty long and fairly informative post about the issue.
  4. #4 Re: Help me understand rockers
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by BrandonHall10 View Post
    That sounds about right. OP be mindful of this before you buy. And search for that thread.
  5. #5 Re: Help me understand rockers
    Oct 2011
    huntley
    I would much rather go cam but rockers would be a lot easier to install. That is a bummer that there is issues with them. I will try to find that thread and hope someone who has put rockers on an 04 plus comments on this.
  6. #6 Re: Help me understand rockers
    Oct 2011
    huntley
    Would 1.95 rockers be a better option than the 1.9's? Would that fit better?
  1. Anyone use zzp heads? Here's something I don't understand
    By CrazyGuy03 in forum Introductions/Noob Questions
    Last Post: 05-17-2015, 07:59 AM
  2. Help me understand this please
    By ThePhoenix98 in forum Turbo
    Last Post: 02-28-2014, 11:49 PM
  3. Just weird. Can someone help me understand this?
    By Gm Man in forum General Tech Discussion
    Last Post: 11-08-2012, 07:07 AM
  4. Don't understand the equalizer
    By OKExplorist in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 11:07 AM
  5. help me to understand
    By vailskier3 in forum General Tech Discussion
    Last Post: 03-22-2009, 09:50 AM
