Thread: ABS/Trac light reset
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #1 Re: ABS/Trac light reset
    SWPA
    My Advance uses one of the better Actron scanners too.
  2. #2 Re: ABS/Trac light reset
    SE Level Member lizahart's Avatar
    Jul 2015
    Canada
    where can I get a scan free of charge in LA?
  3. #3 Re: ABS/Trac light reset
    at your uncles shop. no one does it for free really. the software alone is a couple grand a year to keep the scanner up dated.
    unless you have a newer car and your parts store has a higher end code scanner. it may, or may not scan for abs codes.
  4. #4 Re: ABS/Trac light reset
    Aug 2013
    arlington, tx
    Doesn't the torque app scan the wheel speed sensors?
  5. #5 Re: ABS/Trac light reset
    mine will tell me wheel speed for each wheel. but is never consistent, and i know i dont have hub codes in my car.
  6. #6 Re: ABS/Trac light reset
    Apr 2015
    Columbus, OH
    Yeah torque does but its real laggy and not the actual speed. Like when doing 40 it will show 22 or something. It may help if you locked in cruise and waited for it to level out to see if there is any variance, but I wouldn't trust it enough to change a hub out.
    Top Swapped 01 Imp
  1. Change oil light does not reset
    By Chicot in forum General Grand Prix Discussion
    Last Post: 12-29-2013, 09:09 PM
  2. Oil reset light
    By Acedriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2012, 10:22 PM
  3. Reset Check Engine Light
    By barbschwartzer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-05-2012, 02:05 AM
  4. SES light reset?
    By 98GRANDPRIXGTP in forum General Tech Discussion
    Last Post: 03-31-2010, 11:38 AM
  5. Reset Check Engine Soon Light
    By maingate3133 in forum Introductions/Noob Questions
    Last Post: 08-12-2009, 09:11 PM
