Thread: No Idea What the Problem Might Be
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 No Idea What the Problem Might Be
    SE Level Member philly387's Avatar
    May 2015
    Michigan
    If this is in the wrong section, someone please move it.
    I have a 1998 Grand Prix GTP (Supercharged) with no mods at all except the Transmission was replaced a couple months ago. Transmission was from a Buick Regal (Same transmission as the 1998 GTP)
    I made a few videos while I was driving...Maybe one of you guys can tell me what might be the problem with my car. Engine? Transmission? Torque Converter? I don't know...
    While I'm driving you can see the speed consistently increase (I never change pressure on the gas peddle), but the RPMs stay the same for a bit then rapidly jump up and the speed increase at a faster rate too.
    You can see in all the videos it gets to 23000-2500 RPMs then Jumps about 500 RPMs.
    If anyone has any ideas I would really appreciate it. Don't mind the music playing in the background haha
    10-11 seconds into the video it happens.
  2. #2 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    Here is another video (10-11 seconds in it happens)
  3. #3 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    And here is the 3rd video (10-11 seconds in it happens)
  4. #4 Re: No Idea What the Problem Might Be
    Apr 2015
    Lincoln NE
    It sounds like it is just shifting back down maybe?
  5. #5 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    It's after it shifts.
  6. #6 Re: No Idea What the Problem Might Be
    Mar 2014
    Tucson
    ← not an expert...
    That being said, looks like the TC is unlocking. (?)
  7. #7 Re: No Idea What the Problem Might Be
    Apr 2015
    Lincoln NE
    Ya but is it going from 2nd to 3rd then back to 2nd again? when Mine shifts at lower RPMs it usually only bumps up or down 500-700 Rpm.
  8. #8 Re: No Idea What the Problem Might Be
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by BrandonHall10 View Post
    ← not an expert...
    Thats what I was thinking
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    Quote Originally Posted by jwach View Post
    Sorry, but that just doesn't make sense to me when the car is going faster not slower.
  10. #10 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    ← not an expert...
    Anyway to check this?
  11. #11 Re: No Idea What the Problem Might Be
    Feb 2013
    37.295091, -121.930053
    im thinking if you have tuning software it might tell you not sure tho.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  12. #12 Re: No Idea What the Problem Might Be
    Mar 2014
    Tucson
    I'm trying to think of a way without having a scanner...
    Does that torque app show tcc lockup?
  13. #13 Re: No Idea What the Problem Might Be
    Slipping into 4th?
    Hell I don't know.
  14. #14 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    So my best bet is probably just take it to a shop?
  15. #15 Re: No Idea What the Problem Might Be
    Feb 2013
  16. #16 Re: No Idea What the Problem Might Be
    GXP Level Member
    Mar 2015
    Tomball
    It will show TCC slippage on an 05' but it doesn't show it on my 04' PCM, so it can show it if it is there.
    Jeff
  17. #17 Re: No Idea What the Problem Might Be
    Mar 2014
    Tucson
    Quote Originally Posted by philly387 View Post
    Or find a knowledgeable forum member locally to give you a hand. Probably work for booze. A buddy kept my liver pickled for weeks for the little bit of work I did. Saved him a ton of money over shop rate.
  18. #18 Re: No Idea What the Problem Might Be
    going off the first vid, it looks like 4 th gear is shot. put the car in 3 rd gear, get up past 45 mph and see if it still does that.
  19. #19 Re: No Idea What the Problem Might Be
    May 2015
    Michigan
    Thanks everyone I really appreciate that. I'll try the 3rd gear thing scotty
  20. #20 Re: No Idea What the Problem Might Be
    Enfield, CT
    I had cracked front plugs and my car did something similar to that.
    Sent from my LG G3
  1. Wheelhouse fix idea...horrible problem to have...
    By boosted98 in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2012, 09:00 PM
  2. manual fan switch: good idea bad idea?
    By asite57 in forum General Tech Discussion
    Last Post: 04-22-2012, 01:15 PM
  3. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  4. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
