Thread: impala 3.8
Results 1 to 20 of 39
  1. #1 impala 3.8
    Dec 2014
    TN
    have a 2002 impala 3.8 has ticking sound and i think its the lifter so i changed oil and use motor flush to see if that help but no difference so need help and advice on how to replace the lifters thanks
  2. #2 Re: impala 3.8
    How long have you ran it since doing the oil change?
    I'd even throw some trans fluid in the oil to see if that will help quiet the motor down, it may take several hundred miles to start working.
    And I wouldn't rule out an exhaust leak but I'd have to hear it to see if it's really a lifter noise or something else.
  3. #3 Re: impala 3.8
    Dec 2014
    TN
    after i change oil i basically let it run to temp to see if it stop but it didnt so i turn it off nd then i had to leave for work
  4. #4 Re: impala 3.8
    I would want to look it over extremely well and confirm it's the lifters making noise before pulling it apart to swap them.
  5. #5 Re: impala 3.8
    Kemmerer, Wyoming
    lifter tick is no big deal
  6. #6 Re: impala 3.8
    Dec 2014
    TN
    ok i havent drove it cause it acted like it was losing power when accelerating
  7. #7 Re: impala 3.8
    Dec 2014
    TN
    how much trans fluid would i add
  8. #8 Re: impala 3.8
    Dec 2014
    TN
    yea im have to do the upper and lower gaskets so i just wanted to be sure while i pull apart
  9. #9 Re: impala 3.8
    Dec 2014
    TN
    How much trans fluid would i add also how many lifters it is to replace
  10. #10 Re: impala 3.8
    Dec 2014
    TN
    sound like lifter ticking
  11. #11 Re: impala 3.8
    sounds like a rod knock to me.
    make another vid, this time hold the gas to say 2000-2500 rpm's, then just drop the throttle, let it drop back to idle on its own.
  12. #12 Re: impala 3.8
    Yea that's not lifter tick lol.. Do as Scotty suggested helps eliminate if it's bottom end related.
    04 Comp G.
  13. #13 Re: impala 3.8
    .5 quarts will work.
    And that just sounds like a poor quality phone recording, it can't handle the noises the car makes and it's all choppy and scratchy.
    Try recording the noise with something else.
  14. #14 Re: impala 3.8
    Dec 2014
    TN
    oh no dont say that i hope its not a rod oh no
  15. #15 Re: impala 3.8
    Dec 2014
    TN
    Quote Originally Posted by ScottyDoggs View Post
    ok so rev it to rpm and then floor the gas u mean
  16. #16 Re: impala 3.8
    no. start it up, then hold the throttle to 2500 rpm for 5 seconds, then let off the gas and let it drop back to idle on its own.
    you can stand at the bumper to make the vid, dont bring the cam in close to the engine.
  17. #17 Re: impala 3.8
    Dec 2014
    TN
    dont have nothing elese to record with at the moment when i first started it up
  18. #18 Re: impala 3.8
    Dec 2014
    TN
    ok give me few minutes im go outside and try it again
  19. #19 Re: impala 3.8
    Dec 2014
    TN
    ok i let it drop and it actually dont sound as loud as it did earlier
  20. #20 Re: impala 3.8
    vids private
  1. 04+ GP& Impala
    By luckyg817 in forum 04+ Specifics
    Last Post: 05-09-2014, 10:13 AM
  2. 09 Impala SS
    By BlackCarBlackRims in forum General Grand Prix Discussion
    Last Post: 03-10-2014, 01:03 AM
  3. impala cat's ?
    By dmoney01 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2010, 09:54 PM
  4. 99 Gt VS. 06 Impala SS
    By gtryda in forum Track Sessions and Kills
    Last Post: 11-15-2009, 06:37 AM
