Thread: Negative LTFT from P0107/MAP?
Results 1 to 12 of 12
  1. #1 Negative LTFT from P0107/MAP?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    I already replaced my MAP a few months back to get rid of this code and now it's back. So a two part question...
    1) Could this be the cause of my overly negative LTFT problem?
    2) If it ain't the MAP itself that's causing fault, what else could be causing the fault?
    Thanks peeps
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  2. #2 Re: Negative LTFT from P0107/MAP?
    Dec 2013
    ohio
    Injector?
  3. #3 Re: Negative LTFT from P0107/MAP?
    Well, what is the number is throwing??
    It's not abnormal to see it pulling negative 5-7 while at idle.
    Clean the MAF sensor while your at it, a dirty maf can cause weird numbers.
  4. #4 Re: Negative LTFT from P0107/MAP?
    http://www.obd-codes.com/p0107 that code is low circuit. check the wires to the map for damage. if you see cracks or missing insulation, or bare wire, change that pig tail.
  5. #5 Re: Negative LTFT from P0107/MAP?
    Sep 2014
    St. Paul, MN
    Ordered the wiring last night, thanks.
    MAF is brand new. LTFT drops to -7 on boost but stays below -5 otherwise and will drop to 0 at a red light.
    BrandonHall10 from the board read as bad as -10 at WOT a few weeks back though. But I haven't run it as hard during the time since I got a scanner myself.
    But anyways, back to my original thought; MAP problems can affect LTFT or do I have another problem?
    Thanks people. 😎
  6. #6 Re: Negative LTFT from P0107/MAP?
    Donating Users timboku's Avatar
    Montgomery, IL
    Just outta courisity
    Did you reset the trims after each fix you tried either with scanner or unplugging battery?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  7. #7 Re: Negative LTFT from P0107/MAP?
    Sep 2014
    St. Paul, MN
    Yeah, many times, albeit for other issues.
  8. #8 Re: Negative LTFT from P0107/MAP?
    Sep 2014
    St. Paul, MN
    LOL. So I replaced the pig tail today because the B wire on the old pig tail had snapped... and the P0107 code is gone.
    But now I have P0108 and my LTFT is even worse; as low as negative 12.5% W... T... F...
    And because the wiring had been cut and rejoined before I ever got to it, I am running out of room to redo this.
  9. #9 Re: Negative LTFT from P0107/MAP?
    Sep 2014
    St. Paul, MN
    Also, the ACDelco pig tail I ordered per RockAuto is a thicker gauge of wire than what the prior pig tail had or what I'm trying to connect to. The crimpable connectors that came with the new pigtail aren't even big enough for the wire...
    Anyways, can anybody confirm the following please;
    A: Gray
    B: Green
    C: Red
  10. #10 Re: Negative LTFT from P0107/MAP?
    solder the new pig tail on. toss that crimp bs things in the trash.
    if the colors are the same as old pig tail just match the colors up, solder, and plug it in.
  11. #11 Re: Negative LTFT from P0107/MAP?
    Sep 2014
    St. Paul, MN
    They're not. Pig tail is all gray wires.
  12. #12 Re: Negative LTFT from P0107/MAP?
    ok, so look at the top of the plug and match the wires up to the factory plugs wires. both plugs should say a b c for each wire.
  1. Negative LTFT and resettting trims.
    By industrialfish in forum General Tech Discussion
    Last Post: 01-18-2015, 10:07 PM
  2. Boost reads in the negative?
    By h0wl0ngcanitbe in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2013, 12:17 AM
  3. I got P0107 low lean.. what should I do?
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 04-15-2013, 05:25 PM
  4. p0107 and p0171
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 11:49 AM
  5. P0107
    By mdkoh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2011, 11:46 AM
