Thread: Negative LTFT from P0107/MAP?
Results 1 to 12 of 12
Threaded View
  1. #8 Re: Negative LTFT from P0107/MAP?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    Also, the ACDelco pig tail I ordered per RockAuto is a thicker gauge of wire than what the prior pig tail had or what I'm trying to connect to. The crimpable connectors that came with the new pigtail aren't even big enough for the wire...
    Anyways, can anybody confirm the following please;
    A: Gray
    B: Green
    C: Red
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  1. Negative LTFT and resettting trims.
    By industrialfish in forum General Tech Discussion
    Last Post: 01-18-2015, 10:07 PM
  2. Boost reads in the negative?
    By h0wl0ngcanitbe in forum Audio, Security & Visual Electronics
    Last Post: 09-11-2013, 12:17 AM
  3. I got P0107 low lean.. what should I do?
    By tlawnewtograndprix in forum General Tech Discussion
    Last Post: 04-15-2013, 05:25 PM
  4. p0107 and p0171
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 11:49 AM
  5. P0107
    By mdkoh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2011, 11:46 AM
