Thread: Recommended Engine Mounts
Results 1 to 17 of 17
donjo Recommended Engine Mounts 04-29-2015, 06:23 PM
Russosaur Re: Recommended Engine Mounts 04-29-2015, 07:11 PM
REDCRAPGP Re: Recommended Engine Mounts 04-29-2015, 08:28 PM
Scottydoggs Re: Recommended Engine Mounts 04-29-2015, 08:40 PM
REDCRAPGP Re: Recommended Engine Mounts 04-29-2015, 08:46 PM
coolone Re: Recommended Engine Mounts 05-01-2015, 05:16 PM
REDCRAPGP Re: Recommended Engine Mounts 05-01-2015, 05:17 PM
Scottydoggs Re: Recommended Engine Mounts 05-01-2015, 05:18 PM
REDCRAPGP Re: Recommended Engine Mounts 05-01-2015, 05:31 PM
REDCRAPGP Re: Recommended Engine Mounts 05-01-2015, 05:30 PM
coolone Re: Recommended Engine Mounts 05-01-2015, 05:33 PM
Scottydoggs Re: Recommended Engine Mounts 05-01-2015, 05:34 PM
idrivejunk Re: Recommended Engine Mounts 05-01-2015, 05:40 PM
coolone Re: Recommended Engine Mounts 05-01-2015, 05:47 PM
idrivejunk Re: Recommended Engine Mounts 05-01-2015, 06:03 PM
Scottydoggs Re: Recommended Engine Mounts 05-01-2015, 06:06 PM
donjo Re: Recommended Engine Mounts 05-02-2015, 11:40 AM
  1. #1 Recommended Engine Mounts
    Oct 2012
    Iowa
    I have to replace the front engine mount (#3093) on my GXP. Just wondering what brands out there are the best for the replacement. Can't really find any solid opinions on them. Anchor, DEA, and Westar are the brands I am finding for the car. Thanks for your help!
  2. #2 Re: Recommended Engine Mounts
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I bought some westar and dea "solid" mounts for my car or i think that was the brands. They passed the shake test so im assuming they are actually solid but I've heard many people getting hydraulic ones or they still have fluid in them but pass the "shake" test.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Recommended Engine Mounts
    It's still best to drill in them to check for fluid..
    04 Comp G.
  4. #4 Re: Recommended Engine Mounts
    i got a set of dna mounts too, were not listed as solid, but passed the shake test. a drill bit fixed that test as fluid game running out the two holes.
  5. #5 Re: Recommended Engine Mounts
    Exactly. I wouldn't rely on the shake test. Even though my current mounts are good I need to get around to making a solid set
    04 Comp G.
  6. #6 Re: Recommended Engine Mounts
    Nov 2011
    NY
    what fill do you use? Just plain ol' silicone?
  7. #7 Re: Recommended Engine Mounts
    Probably use window weld. When the times comes I'll search and see wht everybody's using.
    04 Comp G.
  8. #8 Re: Recommended Engine Mounts
    i used p & L adhesive. they be rock hard.
  9. #9 Re: Recommended Engine Mounts
    http://m.homedepot.com/p/Loctite-PL-...0595/202020473
    04 Comp G.
  10. #10 Re: Recommended Engine Mounts
    Concrete it is!
    04 Comp G.
  11. #11 Re: Recommended Engine Mounts
    Nov 2011
    NY
    Hahaha, wouldn't a little play be good? But no leak by removing fluid I understand. Not sure I would want rock hard solid...
    I remember I installed poly bushings on both sides of dogbones, took the round ones out in 10mins because the vibration, omg! Lolz...
  12. #12 Re: Recommended Engine Mounts
    yup. one of their products.
    if they still sold the polyurethane caulk i would have used that, its some bad ass stuff, well was, i cant find it no more.
  13. #13 Re: Recommended Engine Mounts
    Jan 2014
    AR
    Personally, I use Anchor mounts and am neither exceptionally impressed or disappointed, but I use 97-03 GPs.
    FWIW, a guy could try this stuff. Dries like vinyl. http://3mcollision.com/products/seal...ler-08308.html
    I would also think that any decent windshield urethane would be good- http://3mcollision.com/3m-window-wel...609-black.html
  14. #14 Re: Recommended Engine Mounts
    Nov 2011
    NY
  15. #15 Re: Recommended Engine Mounts
    Jan 2014
    AR
    Quote Originally Posted by coolone View Post
    I can't speak on that one, never used it. I think you need a two-part (2K, or catalyzed) product. For chemical resistance. But thats just a guess since I never filled a mount. I have thought of modifying the bracket and using a couple poly mounts instead.
  16. #16 Re: Recommended Engine Mounts
    this is what i would have used. its what they dont sell here no more. http://www.loctiteproducts.com/p/17/...ng-Sealant.htm
    as far as a caulk goes you'll find no better, not even them 20 dollar tubes of the almighty silicone. i had a hose that had a metal copping, all the seams failed, ( from th eold caulk) i had to make and install new copping metal, i used the 20 dollar tubes of this great stuff and a month later guys leaking again. all the seams failed again. used the p&L and i never heard back from him again.
    5 years later you can still push your finger nail into it, it stays firm but still ply able.
  17. #17 Re: Recommended Engine Mounts
    Oct 2012
    Iowa
    Well i went with the Anchor brand, guess we'll see how it is when it comes in the mail.
  1. engine mounts
    By hadzmat in forum Introductions/Noob Questions
    Last Post: 03-28-2013, 07:49 PM
  2. engine mounts??
    By kenjr in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-17-2012, 02:15 PM
  3. Bad engine mounts?
    By justind in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2011, 11:03 PM
  4. Bad Engine Mounts
    By SliceTheRice in forum General Tech Discussion
    Last Post: 04-30-2010, 10:42 AM
  5. engine mounts?
    By elusive racing in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 10:44 PM
