Thread: 3-button to 5-button DIC (04+)
Results 21 to 40 of 51
  1. #21 Re: 3-button to 5-button DIC (04+)
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by TyroElite View Post
    Would this be the correct Male connector as well? I already bought the GMCELL but this looks cheaper for others who may follow with this.
    American International NC-GM31T <br>GM RADIO T-Harness for iPOD
    yeah, that looks like it would work, also.
  2. #22 Re: 3-button to 5-button DIC (04+)
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Finally my GMCELL showed up. there are 3 wires that do not go between the female and male end (they are the ones ment to go to a phone +/- and mute system) Since the DIC board has all 12 pins, I assume I need to attach these to the male end also right? Can you check this in your wiring diagram? (or post the diagram you have and I can check it)
  3. #23 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    I'll look when i get to my home pc, but yeah, i think you should ahead and connect them... but since you need to re-pin the male end, you should be ok (the male end you have will end up with 2 wires coming from each pin, (if you ordered the ammount of pins that i posted, you should be fine)
  4. #24 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    I orderd 25 i think... was cheaper than 20 and figured I'd have a few extras for another project I might look into.
  5. #25 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    Hmm, just realized the pins I bought are female pins. I need male pins to complete this connector. I'll have to order some I think. You know a part no by chance?
  6. #26 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    hmmm crap..
    the male pin should be 12084449
    but mouser sells them in lots of 25,000
    this is a road block.... i think i was envisioning all of the pins being present in the male connector, and just splicing to the wires, i guess. grrrrrrrr
    there are other places on the web that have delpi parts, but will have to dig around some more.
  7. #27 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    alright, more info, man
    part number
    12040902
    mouser is out of stock on these, but i think this particular number is a good GM number, too, so you might call your local dealer and ask about this p/n.
  8. #28 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    No dice from the local dealership. Guess I'll have to find them online.
  9. #29 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    only place i find them online is here, in 10 packs.
    "GM Micro-Pack: 12040902 Ga. 22 Tin Plated, 10/pcs": Sherco Auto Supply
    tho, they're the 22AWG size, was hoping for larger.
  10. #30 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    Would this male pin work instead? 12160551 Its gold plated and 100W but seems like it might work better with 2 wires/pin. Your thoughts?
  11. #31 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    I looked at this one too, and thought it would work, until i looked at it's drawing.
    it's meant for a different connector body... wont work...
    what you may end up doing is using the smaller pins, and just put one wire in there, and come out, and use solder/heat shrink to make your joint outside of the connector.....
  12. #32 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    Hmm... I think I might go ahead and order the pack of 10 you found. I called mouser and theirs won't be in until the end of February. I may also pick up that Ipod t harness I found and see if it would make things easier for others in the future. Thanks for the help.
  13. #33 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    no problem. I'd venture to guess that the ipod adapter one has all the pins in it, i know the similar one that is in my truck has all the pins, as it's a T-harness
  14. #34 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    I looked today and the DIC only uses 8 pins. So I could use it but repin it to the correct spots. It doesn't work straight up the way it is. I'm still ordering the pins I need to redo it completely and when installing my HUD yesterday, I found another connector that if I repin it, I can use a stock wiring harness.
  15. #35 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    what harness did you find?
  16. #36 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    Its a harness for the HUD controls, not the DIC. SOrry for the confusion. That was pretty poorly written. Its C240 on the wiring diagrams if you have them around and care too take a peak.
  17. #37 Re: 3-button to 5-button DIC (04+)
    Oklahoma
    Tyro, where do you find all these automotive connectors? And how do you know what to look for or how do you identify the connectors. There are some in the engine bay I would like to run down a good source for.
  18. #38 Re: 3-button to 5-button DIC (04+)
    Williamsport, PA
    Well, Toasty has helped me quite a bit on my project as you've seen here. I also have the GM service manual that shows connector end views, pinouts, etc along with a part number. From there, its a bit of Google searching.
  19. #39 Re: 3-button to 5-button DIC (04+)
    SW Chicago Suburbs
    x2... connector end views help alot, they have the delphi/gm p/n on them. post up in a thread what you're lookin for.
  20. #40 Re: 3-button to 5-button DIC (04+)
    Oklahoma
    Well first and foremost, I want an alternator male and female connector, but not just necessarily for my car but for another make and model. I was hoping it was just one or two sources for those or like some huge outlet that specialized in automotive connectors.
