Thread: Turn the Key - Everything Shuts Off
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: Turn the Key - Everything Shuts Off
    iirc thats only for old school flat lifters. the roller cams you can just rock on.
  2. #42 Re: Turn the Key - Everything Shuts Off
    Donating Users Uno99's Avatar
    Appleton, Wi
    Good lord your trying everything but what cause my issues a .03 washer just for grins maybe try it. Again even tho my terminal were tight as could be there wad a tiny enough gap it would not complete the circuit. This caused intermitted security light no dash lights no starts from time to time
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  3. #43 Re: Turn the Key - Everything Shuts Off
    battery cables dont kill the power to the starter signal wire. the fat 12 volt battery cable clearly has power to the starter.
  4. #44 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Alright, engine is up and running well, however my oil pressure gauge is reading at a static 150 PSI, and when I unplug it from the sending unit it reads the three dashes, so no reading. Anyone know why that would be? I would like to have the oil pressure gauge working properly - in case something happens - I will know right away. Perhaps a short?
    It's an AEM electronic oil pressure gauge.
  5. #45 Re: Turn the Key - Everything Shuts Off
    you may have a defective sender. or a pinched wire maybe.
  6. #46 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    I'm guessing I can't just pick a new sender up from AutoZone, I'll have to contact AEM?
  7. #47 Re: Turn the Key - Everything Shuts Off
    yeah, dont think its a off the shelf part.
    did it ever work? or is it newly installed?
  8. #48 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    It's newly installed.
    My boost gauge also won't read into the positive... My guess is I tapped into the wrong line?.. It reads vacuum just fine.
  1. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  2. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. Replies: 21
    Last Post: 08-30-2010, 07:41 PM
  5. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
