Thread: shuts off sec after going WOT....why?
Results 1 to 20 of 22
  1. #1 shuts off sec after going WOT....why?
    just lately my car has been doing this. heres what happens-whenever i go full throttle and hit boost, after i let off the throttle a few seconds, anywhere from 2-5 seconds the motor stalls or turns off. the RPMs drop to zero, my fuel needle pegs full, my DIC flashes zero anf my dash lights up-CLE included.
    i changed my CPS sensor and it still does it. this all seemed to happen after i swapped from my LQ4 maf to a LS1 maf which is smaller in diameter. reason why i swapped is because i was cracking LQ4 mafs cause of overtightening them to prevent them from popping off(the lq4s are plastic whereas the ls1 are metal).
    i tried to scan the CEL once the car came to a complete stop but my LS1M even gets an error and reboots itself.
    any ideas?
  2. #2 Re: shuts off sec after going WOT....why?
    also fwiw the ls1 had no screen. dunno if thats something important. honestly the car ran for a couple thousand miles like that before recently this all started.
  3. #3 Re: shuts off sec after going WOT....why?
    bad PCM?
    have you tried using another one then flashing your current tune onto it?
  4. #4 Re: shuts off sec after going WOT....why?
    not yet. this pcm i've been using for a long while. its located right next to the coolant reservoir(my cars a 98) and next to it is my turbo intake piping fwiw. i got another pcm but for some reason its not a 98 year even though the previous owner says it is(my shifts and TC reacts akwardly).
  5. #5 Re: shuts off sec after going WOT....why?
    Charles City, IA
    sounds like a pcm issue, dic flashing 0 means it is in programing mode.
    SMGPFC Two Nipple General
  6. #6 Re: shuts off sec after going WOT....why?
    Could you not re-write the entire PCM file based on whats on the one you have now?
  7. #7 Re: shuts off sec after going WOT....why?
    i dont understand what you mean? could u rephrase that?
  8. #8 Re: shuts off sec after going WOT....why?
    Charles City, IA
    He means do a write entire with the tuner. From what I understand you can dont rewrite a pcm from a different year car.
  9. #9 Re: shuts off sec after going WOT....why?
    you mean a full write reflash to my current pcm or into another pcm of the same year? still a tad confused on the wording here....prolly just me though Xp
  10. #10 Re: shuts off sec after going WOT....why?
    pretty much.
  11. #11 Re: shuts off sec after going WOT....why?
    Charles City, IA
    He meant rewrite the wrong year pcm with you file, which does not work, get a same year pcm and do a calibration only write it should fix you issue.
  12. #12 Re: shuts off sec after going WOT....why?
    Thanks for the info nick.
    Is that for all years period though?
  13. #13 Re: shuts off sec after going WOT....why?
    Charles City, IA
    Not sure, I just know with hptuners you can not rewrite a different year pcm with a different year file.
  14. #14 Re: shuts off sec after going WOT....why?
    ok, then i guess i should look at another 98 gtp pcm to see if that'll work. so u think my current pcm is bad?
  15. #15 Re: shuts off sec after going WOT....why?
    I'd say start there.
  16. #16 Re: shuts off sec after going WOT....why?
    Charles City, IA
    I would say so, it seams like the pcm keeps going into programing mode and the car will not run when that happens.
  17. #17 Re: shuts off sec after going WOT....why?
    well i swapped pcms and did a full write to it via powertuner. took it out and drove around all day doing errands and whenever there was an open stretch of freeway i floored it. did it 4 times and not once did it stall on me. hoping it was the pcm but i'll check again today and put my doubts to rest =)
  18. #18 Re: shuts off sec after going WOT....why?
    Good to hear
    still stuck at 14.6 PSI?
  19. #19 Re: shuts off sec after going WOT....why?
    actually the LS1M registers 14.39psi :-p
    but yes you're correct. i dont know how to setup a 3 bar map sensor to the pcm but its kewl. i bought a boost gauge on ebay that has hi/lo peak warning as well as recall that has its own map sensor. its a marshall instruments scx pro street 2 or whatever. going to install it soon. want to be able to run 16-17psi daily if i can.
  20. #20 Re: shuts off sec after going WOT....why?
    Sounds good, let us know how it goes.
  1. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  2. Car Shuts Off When Engine Warms Up
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-23-2010, 04:22 PM
  3. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  4. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
