Thread: Air Conditioning Does Not Work After Replaced Compressor??
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Air Conditioning Does Not Work After Replaced Compressor??
    try flushing the heater core, maybe its burping air. then your heat gets hot or colder.
  2. #22 Re: Air Conditioning Does Not Work After Replaced Compressor??
    GT Level Member Pokealong1227's Avatar
    Oct 2012
    Oak Grove, MO
    Quote Originally Posted by Jerseydoggs View Post
    The coolant was flushed just a couple months ago, wouldn't that include flushing the heater core?
  3. #23 Re: Air Conditioning Does Not Work After Replaced Compressor??
    not if its got air in it already.
    take both heater hoses off the alt bracket, then put a garden hose to one hose and flush it. put the hoses back on as full as you can keep em.
    my heat was seeming a bit week unless i had just floored it, so today i took one hose off and put a funnel in the hose and poured coolant into, i got no hose to use this time of year. it took a few cups, then it started to push out the alt bracket where i removed the hose, so i guess its full now? not sure but the heat felt better.
  4. #24 Re: Air Conditioning Does Not Work After Replaced Compressor??
    Oct 2012
    Oak Grove, MO
    So that should help my heat be more than warm, but it shouldn't affect my AC should it?
  5. #25 Re: Air Conditioning Does Not Work After Replaced Compressor??
    if the heats weak a core flush always comes to mind. if you hear water sloshing around when you brake or turn, theres air in there for sure.
  1. Replies: 12
    Last Post: 09-02-2014, 11:56 AM
  2. Replies: 2
    Last Post: 01-15-2014, 11:43 AM
  3. replaced intake gaskets now FOB doesnt work
    By rodburner in forum General Tech Discussion
    Last Post: 11-17-2013, 09:44 AM
  4. Replaced A/C compressor
    By Freddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2012, 11:27 AM
