Thread: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
Results 1 to 13 of 13
  1. #1 Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Wondering if this is a reasonably sized turbo for my stock block/heads/valvetrain GTP. Not planning on running more than 10-12 lbs of boost for a while.
    Mainly wondering if the compressor size is too small. Turbine size seems right where I'd like to be at.
    Let me know your thoughts please.
    Thx!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Seems a little small for our engines but I'm no expert.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Mar 2014
    Cincinnati, OH
    I was thinking that may be the case as well but not sure..
    2002 GTP sedan:
  4. #4 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Those numbers are the compressor and turbine housing ar numbers. They tell us nothing about the size of the turbo itself. Could be a way to small 25mm or a huge turbo. Need wheel measurements to determine usefulness.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  5. #5 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Aug 2013
    Sandy, UT
    True. I totally forgot about that part :-P.
    Slow fiero I have to say, those are some wonderfully beautiful 60' times. Stock 4t65 handling that ok?
  6. #6 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Feb 2008
    Canada
    Not even close. I've broken a 4340, and 300m input shaft. And killed multiple chains. Although, the 4340 input shaft and 7/8 chain lived for years with the m90 setup running 1.54-1.6 60' times. After I went turbo all hell broke loose lol. Now have GMR 1" chain and aermet input shaft, no issues with them so far.
  7. #7 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Aug 2013
    Sandy, UT
    Haha I thought so. Thats wonderful... Got any videos of you running at the track? I'd love to drool over them :-)
  8. #8 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    May 2012
    Where winter never ends
    Hopefully I can get near those '60 times.. Though, I doubt Ill be breaking in input shafts GMR 1200 *****es!
    2000 Regal - Winter Beater
  9. #9 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Feb 2008
    Canada
    http://youtu.be/pCQIWKatE7c. Vid of 10.26 run
    http://youtu.be/iUJ6aRjnwkE Friends vid from local 100' race. Wheelie on that run.
    https://youtube.com/user/SlowFiero3800
    Link to my channel. Few vids of my car, and other street cars from around here.
  10. #10 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Mar 2014
    Cincinnati, OH
    http://www.cxracing.com/mm5/merchant..._Code=TRB-T04E
    Thats the one I was considering. Any thoughts?
    2002 GTP sedan:
  11. #11 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Feb 2008
    Canada
    Might as well keep the m90 over that turbo.
  12. #12 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by SlowFiero View Post
    good deal since I ordered a 3.1" pulley today
    2002 GTP sedan:
  13. #13 Re: Will 0.50 AR Compressor / .63 AR Turbine work for my near stock 99 GTP?
    Feb 2009
    flintnasty MI
    The 57 trim version would be better. I run it on my honda.
    The first zzp turbo kits used a 57 trim... those cars to touched high 11s with minimal/no motor work.
  1. would these tips work on a stock 97-03 exhaust?
    By bigtom9492 in forum Engine
    Last Post: 09-19-2013, 07:50 PM
  2. Will 245-50-r16 work on stock 5 spoke gp rims
    By mboase in forum Tires & Wheels
    Last Post: 03-02-2013, 01:46 AM
  3. the stock supercharger belt will work on a 3.4 setup right?
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2010, 11:36 AM
