Thread: Alternator question for 98 GTP
Results 1 to 12 of 12
  1. #1 Alternator question for 98 GTP
    Jan 2015
    ohio
    Hi, I have a 98 gtp that the alternator went out on. I don't have the money right now for a new one, so calling around a few junk yards I learned they are different for n/a and sc. I can't find any for mine, but plenty for a n/a car. Upon searching both part numbers, I've noticed that all the specs are the same. Can anyone please tell me the difference between them? I'm a single dad and don't have much money. I'd hate to go buy one and it not work. Any help be greatly appreciated.
  2. #2 Re: Alternator question for 98 GTP
    N/A and supercharged use the same alt that junk yard is full of crap. Only one that is different is the 3.1 alternator.
    -Edit- Seems I am mistaken.
    Pin 3 looks to be different.
    GTP Alt
    • Pin 1 - Stator
    • Pin 2 - Lamp
    • Pin 3 - Field Monitor
    • Pin 4 - Sense +
    GT Alt
    • Pin 1 - Stator
    • Pin 2 - Lamp
    • Pin 3 - Ignition +
    • Pin 4 - Sense
  3. #3 Re: Alternator question for 98 GTP
    Donating Users timboku's Avatar
    Montgomery, IL
    A 97/98 non sc alternator will fit a gtp. They are the same..you have to find those years only. The alternator bracket changed in 99+...ebay has them cheap.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  4. #4 Re: Alternator question for 98 GTP
    you can use a 99 up alt if you take the alt bracket with it from the junk yard. you'll just need a new pair of elbows.
  5. #5 Re: Alternator question for 98 GTP
    And a new belt.
  6. #6 Re: Alternator question for 98 GTP
    Jan 2015
    ohio
    I thought the junk yard was wrong too lol. But I got the same thing from a few different ones. Even looking it up at AutoZone, I get 2 different numbers. Same exact specs, just different part numbers. Don't make no Damn sense. I don't know why a n/a alternator supposedly won't work. I think it will. I guess only way to find out is to try 😱
  7. #7 Re: Alternator question for 98 GTP
    Montgomery, IL
    It will .. I took one off my mom 97 regal ls and put it in buddies 98 gtp. No issues. As long as its coming from a 3.8 it will work.
  8. #8 Re: Alternator question for 98 GTP
    north carolina
    Click to Enlarge
    (2 Reviews)
    Pure Energy Alternator
    Sale Price:$72.63
    Quantity:
    (8) In Stock
    Part Number: 4735-07136407
    Notes: New
    Condition: New
    Shipping Options:
    Ground
    This Product Fits the Following: Warehouse: C
    Vehicle Engine
    1998 Pontiac Grand Prix 3.8L V6 Supercharged
    www.partsgeek.com
  9. #9 Re: Alternator question for 98 GTP
    hangover park IL
    field sensing and ign + are the same thing, a remote batt voltage refrence to help control the field.
    my 97 gtp has a 2004 L26 (na) alternator and bracket, our 442 is using a 98 L36 riviera cs144 alternator with a 99 ssei harness/pcm.
    as long as your using the correct alternator for the correct bracket your golden, if you upgrade to the cs144 alternator chassis (external fan/140 amps) youll have to swap the connector.
    ~James~ Psychotic Gearhead
  10. #10 Re: Alternator question for 98 GTP
    hangover park IL
    also bear in mind only the up level cars actually used more than one pin.
    high load cars will get the additional remote power sensing, and the G chassis guys and certain others get a battery thermister lead for extra voltage due to internal resistance changes in the battery
  11. #11 Re: Alternator question for 98 GTP
    Jan 2015
    ohio
    Thanks for all the help. I ended up getting one off a 97 lesabre. Looked the same, so I bought it. Brought it home, put it on, and it's been doing great all day!
  12. #12 Re: Alternator question for 98 GTP
    Jan 2015
    ohio
    One more thing I did notice is the pin lay out shows 4 wires. My car only has 2. I even pulled the wire loom back to make sure some wires didn't come out.
  1. '08 gxp ho alternator question
    By masonv6 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2015, 03:08 PM
  2. alternator question?
    By lance4682 in forum General Tech Discussion
    Last Post: 12-11-2013, 09:11 AM
  3. Alternator/regulator question
    By DirtDog in forum General Tech Discussion
    Last Post: 07-12-2013, 11:35 AM
  4. alternator question
    By bluprix in forum Shops and Community Heroes
    Last Post: 07-16-2010, 01:59 PM
  5. Alternator question
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2010, 07:04 PM
