Thread: '08 gxp ho alternator question
Results 1 to 18 of 18
  1. #1 '08 gxp ho alternator question
    Aug 2014
    United States
    I noticed my voltage when I go to work in the morning is 14.5 on the way home it was 12.8, I am doing a stereo upgrade and the total wattage of the system is 2800watts. I bought a HO ALT but now I'm concerned my voltage will drop down like with the stock one because it is pcm controlled. Is there any way to keep my voltage at least steady in the upper 13s. 12.5 or 13 will not be good once the system is on. I don't want to wreck my amps with a low voltage drop. Anyone with knowledge of this that would be great
  2. #2 Re: '08 gxp ho alternator question
    I live here. DirtDog's Avatar
    Jun 2012
    Honestly it should stay around 14.1-15.2. Mine used to drop to below 13 then my alternator went out. Replaced the alt. No problems since. The stock alt can handle that power. I'm pretty sure we have a 220 amp stocker
  3. #3 Re: '08 gxp ho alternator question
    Aug 2014
    United States
    And you own a gxp I take it?
  4. #4 Re: '08 gxp ho alternator question
    Mar 2012
    NC
    Quote Originally Posted by masonv6 View Post
    Yes he does.
  5. #5 Re: '08 gxp ho alternator question
    Jun 2012
    Yes sir
  6. #6 Re: '08 gxp ho alternator question
    Pennsylvania, USA
    If you have any GP that's 05+, the charging system uses a current sensor to monitor battery discharge and changes the voltage accordingly. It's normal to see high 12's or low 13's when there isn't much load on the charging system. I have a HO alternator and I thought the voltage regulator was going out on mine until I figured this out.
    If you're interested, I can post up GM's explanation of the charging system when I get home.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  7. #7 Re: '08 gxp ho alternator question
    Aug 2014
    United States
    If you could post what GM has to say about that, that would be cool
    How does your charging do with your HO ALT. I'm assuming you have a decent system. Does the car notice the extra load while the system is running and give you a decent voltage?
  8. #8 Re: '08 gxp ho alternator question
    Jun 2012
    Actually the current sensor that he mentioned in the above post was discontinued and replaced with a new model in 07. So if u have an early year 07 or before year model u may have the old sensor. Replacing it with the new sensor could help. I also updated to the newer sensor
  9. #9 Re: '08 gxp ho alternator question
    Aug 2014
    United States
    I have a 2008. But I may need to replace it anyways because I am getting the Service Brake Apply Sensor.
  10. #10 Re: '08 gxp ho alternator question
    Pennsylvania, USA
    I apologize for the delay, the site I was getting the info from has been down, but here ya go! You can see in certain situations it's completely normal to have quite a low voltage compared to older charging systems with static voltage regulation.
    2008 Pontiac Grand Prix 5.3L Eng GXP
    BATTERY, CHARGING SYSTEM AND STARTING SYSTEM
    DIAGNOSTIC INFORMATION AND PROCEDURES > BATTERY INSPECTION/TEST > CIRCUIT/SYSTEM TESTING
    CAUTION: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
    • Inspect the battery for a cracked, broken, or damaged case, which may be indicated by battery acid leakage.
      • If there is any apparent damage, replace the battery.
    • Verify the cold cranking amperage (CCA), and reserve capacity (RC) and/or amp hour (AH) rating of the battery to the original battery or original equipment (OE) specification. Refer to Battery Usage .
      • If the battery does not meet or exceed specifications, replace the battery.
    • Verify that the battery cables are clean and tight. The battery terminal bolts should be torqued as specified in Fastener Tightening Specifications .
      • If the battery cable(s) need to be cleaned, clean as required and tighten as specified.
      • If the battery cable(s) are damaged, replace then tighten as specified.
    • Install the J 42000 and follow directions supplied by the tester. See Special Tools .
      • If the tester calls for charging the battery, refer to Battery Charging .
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION
    The purpose of the charging system is to maintain the battery charge and vehicle loads. There are 6 modes of operation and they include:
    • Charge Mode
    • Fuel Economy Mode
    • Voltage Reduction Mode
    • Start Up Mode
    • Windshield Deice Mode
    • Battery Sulfation Mode
    The ECM/PCM controls the generator through the generator field control circuit. It monitors the generator performance through the generator field duty cycle signal circuit. The signal is a 5 volt PWM signal of 128 Hz with a duty cycle of 0-100%. Normal duty cycle is between 5-95%. Between 0-5% and 95-100% are for diagnostic purposes. The following table shows the commanded duty cycle and output voltage of the generator:
    Commanded Duty Cycle Generator Output Voltage
    10 % 11.0 V
    20 % 11.56 V
    30 % 12.12 V
    40 % 12.68 V
    50 % 13.25 V
    60 % 13.81 V
    70 % 14.37 V
    80 % 14.94 V
    90 % 15.5 V
    The generator provides a feedback signal of the generator voltage output through the generator field duty cycle signal circuit to the ECM/PCM, this information is sent to the BCM. The signal is a 5 volt PWM signal of 128 Hz with a duty cycle of 0-100%. Normal duty cycle is between 5-99%. Between 0-5% and 100% are for diagnostic purposes.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > CHARGE MODE
    The BCM will enter Charge Mode when ever one of the following conditions are met:
    • The interpreted fuel rate is greater than 21 g/s and the throttle position is greater than 90%.
    • The headlamps are ON, low or high beam.
    • The wipers are ON for more than 8 seconds.
    • The electric cooling fans are on high speed.
    • The rear defogger is ON.
    Once one of these conditions are met, the generator battery control module will set the targeted generator output voltage to 13.4 volts and then ramp that voltage up to 14.5 volts at a rate of 50 mV per second.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > FUEL ECONOMY MODE
    The BCM will enter Fuel Economy Mode when the calculated ambient air temperature is above 0°C (32°F), the calculated battery current is less than 15 amperes and greater than -8 amperes, and the battery SOC is greater than 80%. Its targeted generator output voltage is 13.0 volts. The BCM will exit this mode once the criteria are met for Charge Mode.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > VOLTAGE REDUCTION MODE
    The BCM will enter Voltage Reduction Mode when the calculated ambient air temperature is above 0°C (32°F); the calculated battery current is less than 2 amperes and greater than -7 amperes, and the generator field duty cycle is less than 99%. Its targeted generator output voltage is 12.9 volts. The BCM will exit this mode once the criteria are met for Charge Mode.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > START UP MODE
    After the engine has started the BCM sets a targeted generator output voltage of 14.5 volts for 20 seconds.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > WINDSHIELD DEICE MODE
    After the engine has run for more than 10 seconds the BCM sets a targeted generator output voltage of 13.8 volts if the calculated ambient air temperature is less that 0°C (32°F). The BCM will stay in this mode until the engine coolant temperature reaches 75°C (167°F) for 10 minutes.
    DESCRIPTION AND OPERATION > CHARGING SYSTEM DESCRIPTION AND OPERATION > CHARGING SYSTEM OPERATION > BATTERY SULFATION MODE
    The BCM will enter this mode when the interpreted generator output voltage is less than 13.2 volts for 45 minutes. Once in this mode the BCM will set a targeted output voltage of 13.8 volts for 5 minutes. The BCM will then determine which mode to enter depending on voltage requirements.
    DESCRIPTION AND OPERATION > ELECTRICAL POWER MANAGEMENT DESCRIPTION AND OPERATION > ELECTRICAL POWER MANAGEMENT
    The electrical power management (EPM) is used to monitor and control the charging system and alert the driver of possible problems within the charging system. The EPM system makes the most efficient use of the generator output, improves the battery state-of-charge (SOC), extends battery life, and manages system electrical loads.
    The load shed operation is a means of reducing electrical loads during a low voltage or low battery SOC condition.
    The idle boost operation is a means of improving generator performance during a low voltage or low battery SOC condition.
    Each EPM function, either idle boost or load-shed, is discrete. No 2 functions are active at the same time. Idle boost is activated in incremental steps, idle boost 1 must be active before idle boost 2 can be active. The criteria used by the instrument panel module (IPM) to regulate EPM are outlined below:
    Function Battery Temperature Calculation Battery Voltage Calculation Amp-hour Calculation Action Taken
    Idle Boost 1 Start Less Than -15°C (5°F) Less Than 13 V - First level Idle boost requested
    Idle Boost 1 Start - - Battery has a net loss greater than 0.6 AH First level Idle boost requested
    Idle Boost 1 Start - Less Than 10.9 V - First level Idle boost requested
    Idle Boost 1 End Greater Than -15°C (5°F) Greater Than 12.0 V Battery has a net loss less than 0.2 AH First level Idle boost request cancelled
    Load Shed 1 Start - - Battery has a net loss of 4.0 AH Rear Defrost, Heated Mirrors, Heated Seats cycled OFF for 20% of their cycle
    Load Shed 1 Start - Less Than 10.9 V - Rear Defrost, Heated Mirrors, Heated Seats cycled OFF for 20% of their cycle
    Load Shed 1 End - Greater Than 12.0 V Battery has a net loss of less than 2.0 AH Clear Load Shed 1
    Idle Boost 2 Start - - Battery has a net loss greater than 1.6 AH Second level Idle boost requested
    Idle Boost 2 Start - Less Than 10.9 V - Second level Idle boost requested
    Idle Boost 2 End - Greater Than 12.0 V Battery has a net loss less than 0.8 AH Second level Idle boost request cancelled
    Idle Boost 3 Start - - Battery has a net loss of 10.0 AH Third level Idle boost requested
    Idle Boost 3 Start - Less Than 10.9 V - Third level Idle boost requested
    Idle Boost 3 End - Greater Than 12.0 V Battery has a net loss of less than 6.0 AH Third level Idle boost request cancelled
    Load Shed 2 Start - Less Than 10.9 V Battery has a net loss greater than 12 AH Rear Defrost, Heated Mirrors, Heated Seats cycled OFF for 50% of their cycle. The BATTERY SAVER ACTIVE message will be displayed on the DIC
    Load Shed 2 Start - Less Than 10.9 V - Rear Defrost, Heated Mirrors, Heated Seats cycled OFF for 50% of their cycle. The BATTERY SAVER ACTIVE message will be displayed on the DIC
    Load Shed 2 End - Greater Than 12.6 V Battery has a net loss of less than 10.5 AH Clear Load Shed 2
    Load Shed 3 Start - Less Than 11.9 V Battery has a net loss greater than 20 AH Rear Defrost, Heated Mirrors, Heated Seats cycled OFF for 100% of their cycle. The BATTERY SAVER ACTIVE message will be displayed on the DIC
    Load Shed 3 End - Greater Than 12.6 V Battery has a net loss of less than 15 AH Clear Load Shed 3
  11. #11 Re: '08 gxp ho alternator question
    Aug 2014
    United States
    So I think if my stereo system is on, I should see some decent voltage considering I will be drawing some decent amps from the battery at the time, and the system should try to run in "CHARGE MODE" considering the amp load!!!!
    NIK12937 Thanks for the posting of this! NIK12937 what kind of voltage are you seeing as far as your setup going considering you have a HO ALT. I would guess you must have some decent current draw from your charging system and battery considering you have bought a HO ALT.
  12. #12 Re: '08 gxp ho alternator question
    Buffalo
    Is the stock alt really 220amps?
  13. #13 Re: '08 gxp ho alternator question
    Jun 2012
    Yes
  14. #14 Re: '08 gxp ho alternator question
    Buffalo
    That's pretty impressive considering we pay upwards of $400-500+ for custom alternators in that range
  15. #15 Re: '08 gxp ho alternator question
    Wichita
    Got the 5V Battery Current Sensor car ran great for a few miles. Then I got to an intersection the battery volts plummeted and the car died. Did I get the wrong sensor?
  16. #16 Re: '08 gxp ho alternator question
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by SallyBabe03 View Post
    Price out an alternator for this car. Cha-ching! LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: '08 gxp ho alternator question
    Wichita
    The battery volts won't go higher than 13.55 and the MPH needle still bounces. And now the car can't be started without being jumped. Even if I try to start it moments after it was just running. This is getting frustrating.
  18. #18 Re: '08 gxp ho alternator question
    Wichita
    Gonna try the 10V sensor & get the battery tested. If this doesn't fix the car well then idk what to do.
  1. alternator question?
    By lance4682 in forum General Tech Discussion
    Last Post: 12-11-2013, 09:11 AM
  2. Alternator/regulator question
    By DirtDog in forum General Tech Discussion
    Last Post: 07-12-2013, 11:35 AM
  3. alternator question
    By bluprix in forum Shops and Community Heroes
    Last Post: 07-16-2010, 01:59 PM
  4. Alternator question
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2010, 07:04 PM
  5. Alternator Voltage Booster question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2009, 07:23 AM
