Thread: Another problem...
Results 1 to 20 of 39
  1. #1 Another problem...
    SE Level Member MattGTP04's Avatar
    Jun 2014
    United States
    I hate to be the guy with all the questions, but I guess somebody has to be.
    Last night while driving home from work, I stopped at a light with my windows down. It became apparent that there was a rattle coming from the front of the car. I experimented on the rest of the drive, and noticed it went away when I increased the throttle, but still happened when stopped and at idle. I looked under the hood when I got back but didn't notice anything unusual, but it sounded like it was coming from below or behind the engine, not up top. Any thoughts guys? I'll be glad to give more info if you need.
  2. #2 Re: Another problem...
    Remove the supercharger belt and see if the noise is still there. If gone, then likely the coupler in the s/c is worn out.
    A simple test atleast.
  3. #3 Re: Another problem...
    Jun 2014
    United States
    After driving it some more and inspecting, it almost sounds like a lifter problem. Anything thoughts?
  4. #4 Re: Another problem...
    Aug 2013
    arlington, tx
    Quote Originally Posted by MattGTP04 View Post
    Have you done any top end work on it lately?
  5. #5 Re: Another problem...
    Jun 2014
    United States
    None at all. The previous owner didn't either.
  6. #6 Re: Another problem...
    Aug 2013
    arlington, tx
    Will the noise change speed with throttle? Like if you give it some gas will the noise get louder or faster?
  7. #7 Re: Another problem...
    Jun 2014
    United States
    See that's the weird part. I work mostly on small engines so I'm not as good with diagnosing larger engines. But it is a rhythmic rattle at idle, like tick-a-tick. (Sorry lol) but when I increase the throttle it goes away
  8. #8 Re: Another problem...
    Aug 2013
    arlington, tx
    Check your coolant and your oil level and see where they are. Both make ticking noises when they are extremely low.
  9. #9 Re: Another problem...
    Jun 2014
    United States
    Oil is full, and coolant is a little low, but nearly full
  10. #10 Re: Another problem...
    Aug 2013
    arlington, tx
    Did you check them with a cold engine? Dumb question but still...haha
  11. #11 Re: Another problem...
    Jun 2014
    United States
    Haha yeah. Both seem normal.
  12. #12 Re: Another problem...
    Aug 2013
    arlington, tx
    Hmm. Anything seem weird before you noticed the noise?
  13. #13 Re: Another problem...
    Jun 2014
    United States
    No, that's why this is so weird. It seems to get louder as the engine gets warmer though
  14. #14 Re: Another problem...
    Aug 2013
    arlington, tx
    Well if it was a lifter noise, it would be coming from the top of the motor. Are you sure it's not coming from the top?
  15. #15 Re: Another problem...
    Jun 2014
    United States
    It's very possible. It really just sounds internal, but closer to the top
  16. #16 Re: Another problem...
    Aug 2013
    arlington, tx
    Well actually that's what I would do. Somebody else might chime in and say to try something else before tearing into it. Can you post a video of the noise?
  17. #17 Re: Another problem...
    Aug 2013
    arlington, tx
    Well looks like it might be time to tear into it and take a look at the LIM
  18. #18 Re: Another problem...
    GTP Level Member
    Aug 2012
    st louis park, MN
    Aren't the 3800 injectors known to be really noisy? Mine are always ticking away like crazy.
    I'm not sure if they'd be loud enough to hear with the hood closed and in your car with the windows down though...
  19. #19 Re: Another problem...
    Jun 2014
    United States
    Finally got a video of it. It's not the best example though. It's so sporadic. Some days it will be 3x as loud, others it can't be heard at all. Today it was somewhere in between. More on the quiet side for sure. You can start to hear it around 0:40 into the video.
    2004 Grand Prix GTP Mystery Sound: http://youtu.be/O7CkiRYoh50
  20. #20 Re: Another problem...
    Jun 2014
    United States
    Anybody have any ideas?
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. MAF problem- maybe?
    By Betsy in forum General Tech Discussion
    Last Post: 12-19-2010, 08:36 AM
  5. Problem
    By mwillis in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 03:54 PM
