Thread: Took the dash off, now the key is stuck in the ignition
Results 1 to 3 of 3
camopaint0707 Took the dash off, now the... 08-12-2014, 06:13 PM
Bluemagic Re: Took the dash off, now... 08-12-2014, 06:35 PM
camopaint0707 Re: Took the dash off, now... 08-17-2014, 02:31 PM
  1. #1 Took the dash off, now the key is stuck in the ignition
    Banned
    Jan 2013
    Colorado
    So I removed the dashboard. And now the key is stuck in the igntion. There is one plug underneath the steering wheel that isn't connected and I can't find what it connects too. It's a black plug with a green/white wire and a black wire. Car starts, moves, goes into gears just fine. The performance shift mode doesn't work anymore but I don't really care about that at the moment. How do I get the key out?!
  2. #2 Re: Took the dash off, now the key is stuck in the ignition
    Dec 2010
    DMV
    There's a hole under the steering wheel use a screwdriver and insert it to release the key. It may have a covering on it. Pop it off and your good to go
  3. #3 Re: Took the dash off, now the key is stuck in the ignition
    Banned
    Jan 2013
    Colorado
    I did get the key out by pushing the solenoid.
  1. Key stuck in ignition
    By chumley in forum Audio, Security & Visual Electronics
    Last Post: 06-02-2013, 10:55 AM
  2. Key stuck in Ignition
    By NIKGTP98 in forum General Grand Prix Discussion
    Last Post: 08-17-2012, 08:17 PM
  3. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  4. 2005 GT Key stuck in dash mounted ignition
    By eebill in forum General Tech Discussion
    Last Post: 10-04-2009, 08:59 PM
  5. Key stuck in ignition
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-08-2008, 06:36 PM
