Thread: How to remove fan switch
Results 1 to 3 of 3
  1. #1 How to remove fan switch
    Quakertown, PA
    Hi guys,
    I am asking for your collective wisdom on how to get to the mechanical fan switch for the heater/AC.
    I have seen some info on removing the plastic of the dashboard to get to the radio, etc. but it didn't seem to be directly
    related to my car. ('02 GP).
    Specifically, if someone can give me step by step instructions on removing whatever I
    need to remove to get to my fan speed switch I would appreciate it. The reason I want to get to the fan
    switch is that only speeds 1, 4, and 5 work. I know it's not the fan resistor since I already replace that and if I
    wiggle the switch (on position #2, for instance), the fan will come on and go off but won't stay on. What I suspect is
    that the contacts on the switch are either corroded or burnt which is causing an
    intermittent connection. I am hoping if I can look at the switch itself, maybe I can
    clean it up. If not, then I may have to replace it.
    If I need to replace it, can anyone tell me where I can get a new one?
    Thank you all,
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  2. #2 Re: How to remove fan switch
    Quakertown, PA
    Anyone???
  3. #3 Re: How to remove fan switch
    St. Louis
    Hit up a JY and find one that is the same as yours. Or if you really want a NEW one, hit up a dealer.
    I've never taken just a switch out of one of these before. Usually just remove the entire head.
  1. How do I remove the power window switch assemble for my 2004 Grand Prix
    By spade76 in forum General Grand Prix Discussion
    Last Post: 09-01-2013, 02:49 AM
  2. How do I remove sunroof switch trim
    By SnowDrift in forum General Tech Discussion
    Last Post: 05-19-2011, 06:55 AM
  3. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  4. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
