Thread: high pitched whine when not on gas
Results 1 to 6 of 6
  1. #1 high pitched whine when not on gas
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    So I noticed a high pitch whining noise coming from the engine the other day...
    it goes away when I touch the gas, comes and goes at idle with the car parked, but really noticeable when coasting at like 40 with the windows down
    what are some things that could cause this? My ac compressor clutch makes a pretty bad grinding noise from time to time and it sounds like it could be coming from that area, so that's where I'm probably going to start. last I checked that was the only pulley that had made any noise or had weird resistance when turning it by hand.
    I haven't investigated further yet and at this point I'm thinking its a pulley, but I figured I'd ask and see if there are any other obvious things I should be thinking about
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  2. #2 Re: high pitched whine when not on gas
    Aug 2013
    McDonald PA
    Power steering pump
  3. #3 Re: high pitched whine when not on gas
    Dec 2013
    maine
    nope, replaced it like 3 months ago so I'd hope not, sounds nothing like power steering whine either, much higher pitched
  4. #4 Re: high pitched whine when not on gas
    Aug 2013
    McDonald PA
    Trans pump
  5. #5 Re: high pitched whine when not on gas
    St. Louis
    Maybe the alternator? Mine makes a high pitched whine when it's cold out for some reason.
  6. #6 Re: high pitched whine when not on gas
    Dec 2013
    WORK
    Post a video of it. I posted one of the sound. check my other post a few days ago I had the same problem
    it was a pcv gasket. take your dipstick out does it suck air in?
  1. High Pitched Whine noise when I press on the gas
    By gentrymartin in forum General Tech Discussion
    Last Post: 07-12-2012, 01:50 PM
  2. High Pitched Horn Problem
    By Hippo Machine in forum General Tech Discussion
    Last Post: 11-26-2011, 10:24 AM
  3. High pitched hum and vibrating sounds?
    By SomeDudeAtHome in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2011, 05:38 PM
  4. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  5. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
