Thread: Weird stuttering/mis/loss of power problem!!! Help!!!!!
Results 1 to 5 of 5
  1. #1 Weird stuttering/mis/loss of power problem!!! Help!!!!!
    Aug 2014
    NJ
    Ok, so I have an 02 gtp. 3.4 mps, 180 t stat, pacesetter headers, cai, ported t body and zzp pcm. I've had it for a year and had no problems. About a month ago maybe 5 weeks, it started stuttering, losing power and missing bad if i gave more than about 50% throttle input. It would only happen once the car was up to temp, around 180-195 degrees. i would have to back off the gas a little and it would be fine. IF THE CAR WAS STILL RELATIVELY COLD, NOT FULLY UP TO TEMP IT WOULDN'T MISS A BEAT. Not a single sputter even at WOT full boost. This is the most confusing and I feel most important clue. No check engine light came on and no codes stored. 2 good techs in my area and myself have been trying to figure out the issue since then. One hooked the car up to his real time scanner and showed the misfire was only on cyl 2 and there were over 500 in a 10 minute period. Still no codes present however. This past week, it's gotten worse. Now it doesn't matter if the engine is cold or hot and I can only get a third of my pedal travel before it starts doing it bad. I can barely get moving sometimes. I've ruled out the coil pack, plug, wire, injector, crank sensor, and just put a new zzp pcm in thinking it has to be that. The replaced PCM has improved this condition but it may only be because the pcm is relearning. Please help. This is a huge problem thats getting worse and I have no clue from this point. We dont think its mechanical because of the inconsistency.
  2. #2 Re: Weird stuttering/mis/loss of power problem!!! Help!!!!!
    Feb 2009
    flintnasty MI
    did you check compression?
  3. #3 Re: Weird stuttering/mis/loss of power problem!!! Help!!!!!
    Aug 2014
    NJ
    yes. all good
  4. #4 Re: Weird stuttering/mis/loss of power problem!!! Help!!!!!
    Aug 2014
    NJ
    ok so new problem. drove it to work and it was exactly as it was yesterday. 8 hours later after work go to start it up and it just cranks and cranks and cranks. The first time it almost started then died, and just cranks now. Clogged cat?
  5. #5 Re: Weird stuttering/mis/loss of power problem!!! Help!!!!!
    Aug 2014
    NJ
    ttt!!!! help
  1. Grand Prix Stuttering Problem
    By MattF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2014, 11:08 AM
  2. Weird Loss of coolant.
    By lanceman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-21-2011, 12:41 PM
  3. Weird Power problem w/ new headunit
    By Noopsky13 in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2011, 09:20 PM
  4. weird power window problem
    By Warbeaver in forum General Tech Discussion
    Last Post: 07-30-2010, 02:59 PM
  5. I had a rebuilt supercharger put on to my 3.8 now it has a stuttering problem
    By 419ryan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 09:19 PM
