Thread: Weird Loss of coolant.
Results 1 to 20 of 32
  1. #1 Weird Loss of coolant.
    jacksonville, florida
    2001 Pontiac Grand Prix Gt... Losing coolant, however no coolant in oil or under vehicle. Runs fine with no problems.There is some dripping of liquid/water at both tailpipes while running. Could it be losing coolant through the exhaust? If so what could be the cause? I was thinking intake manifold gaskets but wanted to see if anyone had any other ideas or experiences.
  2. #2 Re: Weird Loss of coolant.
    check your oil level if it's over full then your intake manifold is leaking coolant into the oil.
  3. #3 Re: Weird Loss of coolant.
    Its likely your UIM is warped or your LIM gasket is shot.
    If that is the case, buy a new UIM and the felpro permadry plus 2nd design and either install yourself or get someone to.
  4. #4 Re: Weird Loss of coolant.
    SE Level Member Dragon1972's Avatar
    Quote Originally Posted by lanceman View Post
    I will surely bet that your upper intake is warped and the coolant o-rings are filling your lim with coolant. Have repaired many of these and if it is not taken care of immediately you won't be driving anywhere.
    Master Certified Automobile Technician
    1997 GP GT-SC
  5. #5 Re: Weird Loss of coolant.
    I'm gonna go with something close to the other guys...
    I'd say your LIM is currently filling with about 1/2 gallon of coolant. It's doing this through a crack in the UIM where the EGR tube goes up through it. Heat cycles and time tend to crack the UIM right where the EGR tube pokes through. on the other side of that plastic is a coolant port.
  6. #6 Re: Weird Loss of coolant.
    ok soooo how difficult is it to change the UIM and LIM gaskets?
  7. #7 Re: Weird Loss of coolant.
    Not to bad if you can turn a wrench pretty decent.
  8. #8 Re: Weird Loss of coolant.
    It's pretty straight forward for car work. I'd pull the TB and look for the coolant in the UIM. If you see that..it's the issue.
  9. #9 Re: Weird Loss of coolant.
    Toronto
    Anyone have a parts list for this problem? My '01 GT started having similar problems this week. I did have a little bit of milk on the rad cap tho. I have heard HG's are not likely to go on these engines so I am hoping it's either the uim or lim gaskets. Is there a DIY for plugging the UIM coolant lines to fix the issue for good when I do the LIM gasket? TIA.
  10. #10 Re: Weird Loss of coolant.
    Here's a how to on the LIM plugging
    http://www.grandprixforums.net/how-mod-lim-46931.html
  11. #11 Re: Weird Loss of coolant.
    Toronto
    That's great, thanks. WIll definately do this when I replace the gaskets. Does plugging the LIM mean I don't have to worry about replacing the UIM if it's cracked, since there won't be any coolant flowing though there any more?
  12. #12 Re: Weird Loss of coolant.
    SE Level Member baker01gt's Avatar
    Sep 2011
    houston, TX
    I JUST had this job done (my brothers the machanic).. mine was leaking below the egr valve onto the block. i guess thats a common place for it to leak.. it took a little while but we also did the valve cover gaskets. (while your in there chech your valve cover gaskets since there right there). ALSO you will probably need to replace the plastic coolant elbows. mine we pretty much shot once they were pulled out.. i tried to do everything i could while i had it apart so i just bought a top end gasket set and am saving the head gaskets for my project engine! goodluck! (the coolant elbows are about $3.50 FYI)
  13. #13 Re: Weird Loss of coolant.
    Grand Rapids, MI
    For you n/a guys, THIS is what can happen if you do not replace your leaking/warped UIM.
  14. #14 Re: Weird Loss of coolant.
    Ohio
    Quote Originally Posted by brandonl2000 View Post
    ill trump this brandon lol
  15. #15 Re: Weird Loss of coolant.
    Jello^^^^?
  16. #16 Re: Weird Loss of coolant.
    Grand Rapids, MI
    Jello^^^^?
    dexcool showas. partay in the combustion chambers!!
    lolz. seriously. that=hydrolocked.
  17. #17 Re: Weird Loss of coolant.
    Toronto
    OK, so I got the new UIM, LIM Felpro gaskets, plastic OEM gasket for between the UIM and LIM, coolant elbows, t-stat, oil and filter and coolant. About to dig into this tomorrow morning. I am also gonna run and grab some new plugs in the morning before I start. Anything else to look for/do while i am doing this job? Thanks.
  18. #18 Re: Weird Loss of coolant.
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    What type of coolant? Anytime is a good time to flush and switch to Prestone any color.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  19. #19 Re: Weird Loss of coolant.
    Toronto
    Quote Originally Posted by Durk Diggler View Post
    I have 3 jugs of Prestone Any Colour Pre-Mix sitting in my garage ready to go.
  20. #20 Re: Weird Loss of coolant.
    Quote Originally Posted by cornflake View Post
    Why do you waste your money on premix, all you are doing is paying for 1/2 gallon of distilled water with your coolant. Just go to the store and buy the cheapest gallon of drinking water and mix it with a gallon of straight coolant, same thing and cheaper in the long run.
    1997 GP GT-SC
  1. determining coolant loss
    By Jakegday in forum General Tech Discussion
    Last Post: 08-01-2010, 03:03 PM
  2. 02 gtp coolant loss
    By froggy73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 10:28 AM
  3. Total coolant loss
    By Jus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2010, 06:56 PM
  4. Mysterious coolant loss ...
    By timweidner in forum General Tech Discussion
    Last Post: 03-13-2010, 09:33 AM
  5. overheating and big loss of coolant
    By milehighmark in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 05:31 PM
