Thread: Grand Prix Stuttering Problem
Results 1 to 14 of 14
  1. #1 Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    I have an 02 GP and for a while it's been sputtering, it happens when I'm driving and the car lurches slightly when it happens, it also happens while idling. The car isn't giving any error codes. I was thinking maybe the plugs or wires, MAP or MAF sensors or maybe the fuel injectors are dirty? Anyone have more insight into this?
  2. #2 Re: Grand Prix Stuttering Problem
    Florida
    How old are the plugs and plug wires??
    Quick test of the MAF is to unplug it, and see if it runs better.
    Check engine light doesn't flash on/off does it? (means there's a misfire)
  3. #3 Re: Grand Prix Stuttering Problem
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    i would check plugs, wires, and coils.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Grand Prix Stuttering Problem
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Quote Originally Posted by MattF View Post
    Do you do regular matinence on the car?
    I went NA when a whore left -$300 in my bank account.
  5. #5 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    Quote Originally Posted by indygrandprix View Post
    I do regular maintenance on it but I've only had it for like a year. I just unplugged the MAF sensor so we'll see if it runs better when I drive it in a couple hours. I also replaced the front three plugs just a couple days ago but haven't gotten to the back three yet because they're such a pain in the ass. Should I replace the plug wires as well?
    And my gauge cluster isn't working at the moment so I can't see if the check engine light is flashing but when I hooked the computer up to it if there was a misfire it would have told me correct?
  6. #6 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    Unplugging the MAF sensor did not result in the car running more smoothly. Recently replaced the plugs so I'm going to go ahead and swap out the plug wires tomorrow too and I have a fuel filter on the way since they're so cheap and I'll change that. If it's none of that is it most likely the fuel pump?
  7. #7 Re: Grand Prix Stuttering Problem
    see how it is with new wires. they go bad.
    a scanner would show if it had misfires. if its one that shows some live data.
  8. #8 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    Would bad plugs or wires cause the car to physically shut off? Because it has done that twice before, once while coasting down a large hill and once while coasting up to a stop light
  9. #9 Re: Grand Prix Stuttering Problem
    Jun 2012
    Illinois
    check your vacuum lines and see if theres any cracks in them. I've mostly had a problem with the T that is underneath the s/c snout...that is if you're supercharged. I had a problem where it stalled randomly and that was the problem. Take some carb cleaner and spray down the lines, if there is a jump in rpms... you found a leak
  10. #10 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    How many different vacuum lines are there? And how hard are they to replace?
  11. #11 Re: Grand Prix Stuttering Problem
    all them thin hard plastic lines are your vac lines.
    ive changed over 1/2 of mine for new flexible vac lines and new T's.
  12. #12 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    Approximately how much do they cost and would AutoZone carry them, like meaning would they have to order them or would they already have them there?
  13. #13 Re: Grand Prix Stuttering Problem
    they sell it by the foot, less then a dollar a foot too. if you get about 4 or 5 feet, thats more then enough to replace the vac lines.
    you may need a fatter hose, then push a thinner line inside it and a T or a Y for any evap lines.
    it cuts with a razor like butter.
    some pics of my lines.
    evap off the TB, the fat hose there looping to the back of the engine has a hose inside the fat hose, then to the plastic line. this goes to my evap solenoid.
    this line runs from the boost by pass to the fuel pressure regulator with a T, then under the snout to another T, then it ends at the map sensor.
  14. #14 Re: Grand Prix Stuttering Problem
    Sep 2012
    Cedar Rapids, Iowa
    Thank you for the pics they're very helpful. I'll replace my back three plugs and all the wires as soon as the high here gets above 0. And if that doesn't work I'll take a look at the vacuum lines
  1. 04 Grand Prix Stuttering on acceleration
    By NewtoGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-24-2014, 11:57 AM
  2. Grand prix problem
    By lorrodriguez in forum Introductions/Noob Questions
    Last Post: 11-22-2012, 12:07 PM
  3. P0102 code, stuttering stalling 3.8L grand prix gt
    By randybill in forum General Tech Discussion
    Last Post: 10-07-2010, 09:25 AM
  4. I had a rebuilt supercharger put on to my 3.8 now it has a stuttering problem
    By 419ryan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 09:19 PM
  5. Stuttering problem under heavy boost
    By 02gtp2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2009, 12:35 PM
