Thread: front end clunk.
Results 1 to 20 of 26
  1. #1 front end clunk.
    SE Level Member 13aceofspades13's Avatar
    Oct 2013
    Ionia
    2008 Pontiac grand prix base model, 3800 N/A engine L-26, 91,200 miles.
    i have some modifications done but nothing serious, a intake, a pulley, flipped the dogbone bushings, did some stuff too the exhaust, really simple stuff, if any of this stuff helps.
    ok enough of the chatter, i checked the forum and did some research but i am sort of stumped on this one, power breaking will not bring on the clunk, but accelerating in a straight line will, but once the clunk happens it wont clunk again accelerating only in reverse, then once you have had the clunk backing up it wont clunk again in reverse untill it has clunked again accelerating forward. it seems that the steering wheel being turned assist the clunk...
    i saw this TSB on the mounts that hold the steering rack too the sub frame causing a clunk similar but this clunk happens usually when steering, my clunk typically happens when accelerating or backing up. i am also thinking a CV joint may be causing the clunk but yet again power breaking will not bring along the clunk so its hard too say.
    do you guys think this can be caused buy the mounts holding the rack too the subframe or should i focus more on the CV shafts, ill also try too get ahold of a chassis ear some time.
    "Foxy" 2008 Pontiac Grand Prix Base model, Intake, 5.5 water pump pulley, thrush turbo muffler, flipped dogbones, MSD 8.5MM super conductor Wires, Accel super coils.
  2. #2 Re: front end clunk.
    Jan 2014
    AR
    I would inspect the engine's (lower) mount and the transmission mount, then the control arm bushings and ball joints, then the strut mounts.
  3. #3 Re: front end clunk.
    Apr 2011
    Vassar, Mi
    My car had similar symptoms when I first bought it. All the control arm bolts were loosened up. Put the impact on them and hammered them down and it went away
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  4. #4 Re: front end clunk.
    Oct 2013
    Ionia
    thanks for your replies, i have replaced the engine mount because that was bad, checked the ball joints and control arm bushings all that jazz. will check more and tighten the strut bolts.
  5. #5 Re: front end clunk.
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    Also check to make your fender braces under the hood are all tight.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  6. #6 Re: front end clunk.
    Oct 2013
    Ionia
    alright guys strut mounts look really rusty what do you think?
  7. #7 Re: front end clunk.
    Jan 2014
    AR
    Is there supposed to be a pic of the rusty mounts?
    So the engine mount was bad and you replaced it but the trans mount is still original? Thats a clue...
  8. #8 Re: front end clunk.
    Oct 2013
    Ionia
    this is a passenger side photo of the top part of the strut mount and its still bolted too the car... its got enough rust on it i can scrape some of it off with my finger nails, it is also missing some sort of rubber ring that the drivers side has. when i turn the wheel sometimes i get a groaning noise similar sound too what the strut mounts make when the bearings are bad in them, that is what the issue probably is.
    this is the drivers side
  9. #9 Re: front end clunk.
    Oct 2013
    Ionia
    no i do not have a picture of the rusty mounts but i can get one for you, how i descovered the engine mount was bad was testing for excessive play in the CV joints and sort of rocking the tire back and forth i watched the whole engine shimmy pretty much off the dogbone bushings and transmission mount like the engine mount wasn't doing anything, just watching the whole engine shimmy back and forth... yea didn't think it was supposed too be doing that, and i replaced it and it stopped so yea, checked the transmission mount and visually it looked ok, the clunk does not appear too be coming from the area of the transmission either, the clunk is coming from passenger side...
  10. #10 Re: front end clunk.
    look like this? my engine was twisting all over the place.
  11. #11 Re: front end clunk.
    Oct 2013
    Ionia
    LOL! WOAH! no it wasn't that bad yet it had some cracking and stuff but the biggest thing was it didn't seem to be doing anything, it didn't look very bad but holy crap did the engine shake all over the place when i shook the wheel too check CV shaft play! replaced it with the new one and it stopped, in fact the old one hardly looked bad at all, most certainly not that bad!
  12. #12 Re: front end clunk.
    that didnt clunk either. not kidding. but the engine sure did jump all over when shifted in and out of gear. in drive the whole engine twisted in the bay.
  13. #13 Re: front end clunk.
    Oct 2013
    Ionia
    that is bar none the worst front engine mount i have ever seen, i have seen some bad ones in my day but that one takes the cake, my old 98 regal LS had one pretty bad, but that one... i am suprised you didn't hear any sort of noises, good thing you caught that, could of killed a set of CV joints or something.
  14. #14 Re: front end clunk.
    your strut mounts there, hood open car running stand at the door and crank the wheel left and right, watch the center parts. if they move a lot back and fourth they are bad.
  15. #15 Re: front end clunk.
    Oct 2013
    Ionia
    alright ill give that a try! thanks!
  16. #16 Re: front end clunk.
    if they move a lot thats a clunk over bumps. at least it was in my car.
    also check the rubber out under the plate under the center bolt, if it looks melted they are also shot.
  17. #17 Re: front end clunk.
    Oct 2013
    Ionia
    usually when they go bad they tend too make a groaning noise as the bearings are shot the plate resists rotation and twists the spring, causing a groaning clunking noise when it does finally rotate.
    https://www.youtube.com/watch?v=khZ16AOztT4
  18. #18 Re: front end clunk.
    yup. that sound too. didnt hear that but thats the top of the strut bouncing around when the wheels turned.
  19. #19 Re: front end clunk.
    Oct 2013
    Ionia
    it sort of makes that noise, and groans too, i think thats what the clunk is because its loudest when the wheel is turned over hard too the left backing up out of the driveway, clunks when accelerating in a straight line too so thats why i am so suspicious that is what the noise is, ill do what you suggested tomarrow morning, its dark right now so i can't see them.
  20. #20 Re: front end clunk.
    if your struts pass the 3 bounce test, less then 3 bounces and they should be good still. most will only bounce 1.5 times.
    but if good unless you have air tools and a spring compressor, i dont, so i took the struts off the car then took them, with 2 new strut mounts to a front end shop and had them change em, cost me like 25 bucks for the pair.
  1. Front end clunk/click.
    By silvermistgt2002 in forum General Tech Discussion
    Last Post: 06-20-2014, 10:51 AM
  2. 2004 Grand Prix Front End Clunk - TSBs?
    By Overkill in forum General Tech Discussion
    Last Post: 04-27-2012, 03:08 PM
  3. Front End Clunk
    By jcgre3n in forum General Tech Discussion
    Last Post: 03-29-2012, 05:41 PM
  4. 01' GTP Front End Clunk
    By Comanche1959 in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2012, 01:55 PM
  5. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
