Thread: Front end clunk/click.
Results 1 to 20 of 24
  1. #1 Front end clunk/click.
    Iowa
    Seems to be a common problem judging by some of the other posts I have read. 2 problems currently with this car.
    1. Clunk in front end while traveling at speeds of 15-40 mph when I hit bumps in the road. It has been getting worse over the last 6 months. I replaced the strut, mount and all that about 4 months ago due to bad struts, and thinking that might have been the problem. Did not fix the issue. also replaced the sway bar end links. Other thoughts at this point are either the control arms, or sway bar bushings.
    2. Click in the front of vehicle, and under the driver side dash. this DOES NOT happen when I am driving, only when stopped and the wheel is moved back and forth quickly. I can feel it in my feet, and in the wheel. It did have a very slight almost not noticeable click when I bought the car in 2011 but it also has gotten worse. Both front out tie rods are new, now play in anything when I checked the inner tie rods. My thoughts at this point are the steering shaft, or steering rack bushing. I don't think its the rack because the steering is still perfect with no dead spots, or hard to turn spots.
    Thoughts?
  2. #2 Re: Front end clunk/click.
    HUDSON
    For # 2 check you rack mounting bolts, make sure they are tight.
  3. #3 Re: Front end clunk/click.
    Iowa
    Quote Originally Posted by QUICKSILVER462 View Post
    Is is it common for them to come loose?
  4. #4 Re: Front end clunk/click.
    the main sway bar bushings go bad. the ends of the sway crack and clink. lca's will clunk.
    #2 you feel this clicking only when you first start the car and drive off? if so it normal.
  5. #5 Re: Front end clunk/click.
    Iowa
    No. When driving there is no click. Only when car is running, in park, and the wheel is wiggled quickly. Doesn't matter if it's freshly started or been running for hours.
  6. #6 Re: Front end clunk/click.
    Jun 2014
    las vegas
    #2 you feel this clicking only when you first start the car and drive off? if so it normal.[/QUOTE]
    Yes I have the clicking coming from the drivers side only when first taking off? Why is this normal and what is it? Thanx for any response. I have a 97 GTP with 40,000 miles (original)
  7. #7 Re: Front end clunk/click.
    Quote Originally Posted by darryl5 View Post
    Yes I have the clicking coming from the drivers side only when first taking off? Why is this normal and what is it? Thanx for any response. I have a 97 GTP with 40,000 miles (original)[/QUOTE]
    its the abs self test, all w bodys with abs do it. it will self test in reverse or forward after you start the car and drive off. its like a crunch sound. if you ride the brake pedal you can feel it sometimes too. or if you hit the brakes when its does the test.
  8. #8 Re: Front end clunk/click.
    could be the strut mounts. pop the hood then crank the wheel back and fourth to replicate the sound, watch the center round part of the strut mount with the nut in the middle, if the center is moving it could be your clunk.
  9. #9 Re: Front end clunk/click.
    Iowa
    Struts are new and so are the mounts. It made the noise before struts too so I think it's probably the control arms. The clunk only occurs when I'm driving between 15-40 mph. When I'm not moving it's only the slight click in the steering column
  10. #10 Re: Front end clunk/click.
    it could be the ball joints. or the lca bushings.
    or even a inner tie rod.
  11. #11 Re: Front end clunk/click.
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Steering intermediate shaft sounds like the parked popping sound. Could also be associated the other too. Gm had a few car lines with this type issue.
  12. #12 Re: Front end clunk/click.
    SE Level Member SwishGTP's Avatar
    Feb 2014
    Jersey
    Had a popping in my front passenger wheel...it did it whenever the wheel and suspension would flex. It was the ballpoint...alost had the control arm replacedreplaced
  13. #13 Re: Front end clunk/click.
    GTP Level Member
    Aug 2012
    st louis park, MN
    Quote Originally Posted by silvermistgt2002 View Post
    Thoughts?
    I have both of these noises on my car and I haven't been able to fix them yet.
    #1 I think my version of your problem may be my brake pads jumping around in the caliper. Try applying the brakes lightly and hitting your favorite bump; did the noise go away? It did for me! Now you just have to learn to ride your brakes under 40 mph.
    #2 I found the exact same issue with my car last year. Since it only does it when shimmying at stop condition, I stopped shimmying the wheel while stopped (it still annoys me though)! In all seriousness, it sounds like you've replaced or checked a lot of the usual suspects and some of the things I thought about replacing.
    I'm very curious to know what you are able to find on either of these issues. Keep us informed of any progress!
  14. #14 Re: Front end clunk/click.
    Iowa
    I will keep you posted. I think I am going to do the Control arms, sway bar bushings, and steering shaft. So hopefully that will take care of the problem.
  15. #15 Re: Front end clunk/click.
    save the intermediate shaft for last. it sucks to swap.
  16. #16 Re: Front end clunk/click.
    GTP Level Member
    Aug 2012
    st louis park, MN
    One other thing, I think last year I applied a bit of extra silicone based lube to the backs and ends of the pads where they slide back and forth in the caliper. If I remember correctly, they quieted down for a bit. Good luck on the replacements.
  17. #17 Re: Front end clunk/click.
    Iowa
    Any tips to keep every thing aligned good enough to drive after I'm done?
  18. #18 Re: Front end clunk/click.
    when you change the lca's you'll need an alignment right afterwards so plan your repairs around getting to a shop asap.
    sometimes the wheel will be straight, other times it will be off a little bit to one side. it wont be all that far out of alignment tho.
    the sway bar has zero to do with your alignment, so its r & r part.
  19. #19 Re: Front end clunk/click.
    Iowa
    Yea I know I'm just saying keeping it straight enough to drive to the shop lol
  20. #20 Re: Front end clunk/click.
    not much you can do with lower control arms, they are what they are when you bolt them in. new parts always throw the alignment off some.
    tie rod ends tho. leave the old lock nut in place, then remove the old tie rod, then install the new tie rod right up to the old locking nut. thats as close as your ever gonna get with tie rods.
  1. Replies: 26
    Last Post: 07-27-2012, 11:13 AM
  2. 2004 Grand Prix Front End Clunk - TSBs?
    By Overkill in forum General Tech Discussion
    Last Post: 04-27-2012, 03:08 PM
  3. Front End Clunk
    By jcgre3n in forum General Tech Discussion
    Last Post: 03-29-2012, 05:41 PM
  4. 01' GTP Front End Clunk
    By Comanche1959 in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2012, 01:55 PM
  5. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
