Does anybody have specs on these bolts? I cant find them. Are they 15mm or 10?
Sent from my SCH-I545 using Tapatalk
What I do is when I take something off is to put bolts back in the holes they came from like the LIM or alt bracket ect. I did that and my dad as able to put the front vc and db bracket back on without ever touching a 3800 before by himself or having the internet.
Sent from the Milky Way
if you have a new gasket take the TB off and clean it up. use new gasket. nothing scary about it.
take your maf out first tho, nothing but maf cleaner should touch the maf or it "will" die.
The throttle body I used a whole can of TB cleaner on it with a tooth brush to clean it.
Before
After
Depending how bad it was, mine had so much buildup the throttle would stick closed. Also cleaning improved throttle response on my butt dyno
Its a torx security bit isn't it, thanks GM.
you have a hacksaw? or a grinder with a thin blade? if so cut a slot across the security torx bolts, (thats the tool you need security torx bits ) and use a flat head screw driver to remove the bolts.
I bought a set when I had to fix my xbox controller luckily it had one that fit the MAF or basically anything connected to the TB
Id put the TB on later, because might aswell clean it while its off. Same with the MAF if it hasnt been cleaned but only use MAF cleaner on that.
