Thread: Leaking gaskets need diagnosed (with pics)
Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 228
  1. #101 Re: Leaking gaskets need diagnosed (with pics)
    Put a towel down in the valley between the heads to keep any gunk from falling in there. That's called the lifter valley. Then.. yes.. scrape clean. Spray cleaner on rag and wipe surface.
    Yes on doing valve cover gaskets. Although..I'd suggest you clean your surfaces of the LIM and heads, clean your bolt threads for the LIM bolts, get the sealant you are going to put on the bolt threads ready.. put a blob of RTV in the corner where the Head meets the block (4 corners) then put your gaskets in place, another blob in the corners again and sit your lim in place. Now apply your sealant to one bolt at a time and put in all 12. Hand tighten in a criss cross pattern starting in the middle and working your way outward. Then torque them to 15ft lbs if you have the aluminum gaskets, 13ft lbs with plastic gaskets.
    Once the LIM is all set. Then I'd move on to the valve covers. Clean the surfaces, put your new grommets and gaskets in places, torque bolts to 87 inch lbs.
  2. #102 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    So I put a blob right on this crevice?
    Sent from my SCH-I545 using Tapatalk
  3. #103 Re: Leaking gaskets need diagnosed (with pics)
    Yes sir.. all four corners
  4. #104 Re: Leaking gaskets need diagnosed (with pics)
    Before you put the gaskets down.. and then after
  5. #105 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    This gasket is a real PITA to remove!
  6. #106 Re: Leaking gaskets need diagnosed (with pics)
    Yes..it sure can be. Be careful of that sensor under your thermostat area. It's your coolant sensor and about $25
  7. #107 Re: Leaking gaskets need diagnosed (with pics)
    i see bill has hooked you up good.
    that area where the gasket wont come off. I used a board and sand paper wrapped around it, then sanded it off, used like 100 grit paper.
  8. #108 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    These both came in my lim kit. Dont I only use the one on left?
  9. #109 Re: Leaking gaskets need diagnosed (with pics)
    match them up to your old ones. one is for a n/a engine the other is for the supercharged lim.
    mine were orange lol
  10. #110 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok. At what point should I put my new coolant elbows on?
  11. #111 Re: Leaking gaskets need diagnosed (with pics)
    if you took the alt bracket off put them back in when you do the alt bracket.
    so put the lim on first in that case.
    if your like me and didn't take the alt bracket off, you make sure the lim is dry, slide the upper elbow into the lim, then lower the lim into places you slide it into the bracket.
  12. #112 Re: Leaking gaskets need diagnosed (with pics)
    oh, if no one said it yet. make sure you clean off the threads of the lim bolts and put some plumbers thread sealant on them when you put them back in.
    not doing this can cause the bolts to leaks later on.
  13. #113 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    LIM put back on. Hopefully bolts are to correct spec. This torque wrench I got, the 0 lines up below the 10 line so when I turned the dial to 5 it was only a little above the 10 line so hopefully that still means 15.
  14. #114 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Also if it hasn't been said, make sure you put the bolts holdin down the alt in the right holes. Some people have punched a hole in the rear valve cover before.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  15. #115 Re: Leaking gaskets need diagnosed (with pics)
    pretty sure thats impossible on a 97 alt bracket. iirc thats a newer style bracket issue.
    the 97-98 bracket also clears the rear valve cover, no need to loosen it up to remove the cover.
  16. #116 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Dayton, OH
    Ohhh disregard then.
    2012 F150 STX
  17. #117 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    What do you guys read this as?
  18. #118 Re: Leaking gaskets need diagnosed (with pics)
    close enough lol
  19. #119 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Hahaha I like it
  20. #120 Re: Leaking gaskets need diagnosed (with pics)
    looks like its 1/2 way to 20 so as long as no bolts broke its all good.
    most will do it by hand. just past snug. i like to use the t wrench myself.
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
