Does anybody have specs on these bolts? I cant find them. Are they 15mm or 10?
http://img.tapatalk.com/d/14/06/25/neraqyva.jpg
Sent from my SCH-I545 using Tapatalk
I got a tad bit disorganized. These are my best guess.
http://img.tapatalk.com/d/14/06/25/e4ababaz.jpg
What I do is when I take something off is to put bolts back in the holes they came from like the LIM or alt bracket ect. I did that and my dad as able to put the front vc and db bracket back on without ever touching a 3800 before by himself or having the internet.
Sent from the Milky Way
Yeah I put most stuff into bags. Got sloppy at the end though
They fit fine. I need to decide if I wanna replace my TB gasket or not...
if you have a new gasket take the TB off and clean it up. use new gasket. nothing scary about it.
take your maf out first tho, nothing but maf cleaner should touch the maf or it "will" die.
Got it off. What all should I Clean now? Its just all black
The throttle body I used a whole can of TB cleaner on it with a tooth brush to clean it.
Before
http://img.tapatalk.com/d/14/06/25/ujeny9es.jpg
After
http://img.tapatalk.com/d/14/06/25/uhuse8ej.jpg
I dont have tb cleaner so if I remove the maf can I use brake cleaner?
clean all that black crap in those pics. open the brass flap clean its sides and the walls.
carb and choke cleaner works. or brake cleaner.
Depending how bad it was, mine had so much buildup the throttle would stick closed. Also cleaning improved throttle response on my butt dyno
Ok and I don't have the tool to remove screws from maf. Mines not terribly dirty
Its a torx security bit isn't it, thanks GM.
Yea of course it can't be something everyone has.
you have a hacksaw? or a grinder with a thin blade? if so cut a slot across the security torx bolts, (thats the tool you need security torx bits ) and use a flat head screw driver to remove the bolts.
I'll pick up the right tool. Can I just put the TB on later and continue with reinstalling everything else?
I bought a set when I had to fix my xbox controller luckily it had one that fit the MAF or basically anything connected to the TB
Id put the TB on later, because might aswell clean it while its off. Same with the MAF if it hasnt been cleaned but only use MAF cleaner on that.
