Thread: Leaking gaskets need diagnosed (with pics)
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 181 to 200 of 228
  1. #181 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Hahaha I'll think about it, just for you
    Sent from my SCH-I545 using Tapatalk
  2. #182 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Filling it up right now
  3. #183 Re: Leaking gaskets need diagnosed (with pics)
    rodger.
  4. #184 Re: Leaking gaskets need diagnosed (with pics)
    oh, before you fire it up. turn the key to run, then go look for fuel leaks by the rain and injectors, if its all dry, fire it up.
    you see or smell gas turn the key off asap.
  5. #185 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Sooooo uhm I filled up with 1 gal and it seems to be full.......
  6. #186 Re: Leaking gaskets need diagnosed (with pics)
    turn the key to run, check for leaks, no leaks fire it up, then top off the rad as it takes it in the engine.
  7. #187 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    When do I bleed it then? After both gallons are in?
  8. #188 Re: Leaking gaskets need diagnosed (with pics)
    you bleed it after its full and running for a while. when the fans come on. then bleed it.
    the rad only holds a gallon. every things normal.
  9. #189 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    So I bought 2 gallons premix. I know you dont like it but still haha. I only need one? I fired it up and kept pouring and the rad cap overflowed again.
  10. #190 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Oh one gallon into the resevoir also?? Its a mess though
  11. #191 Re: Leaking gaskets need diagnosed (with pics)
    its ok, just cost more, my wallet didnt feel a thing.
    it will burp some when the t stat opens for like 2 seconds, the block was still full so theres a gallon or so still in there.
    check for gas leaks yet?
  12. #192 Re: Leaking gaskets need diagnosed (with pics)
    Quote Originally Posted by 2FASTGTP View Post
    forget the over flow
  13. #193 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok so I just gotta let the engije run for a while and continuously pour both gallons right into rad?
  14. #194 Re: Leaking gaskets need diagnosed (with pics)
    it will only take what it takes, maybe a bit more of the second gallon.
    if you flushed it to clean water first, this is why i like straight antifreeze. cause it will mix with the water in the block.
    your mix will come up weak. if the block has water in it now and your using the pre mix.
  15. #195 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ill just fill it up from time to time if need be. So youre thinking I might just need a bit more of the 2nd gallon?
  16. #196 Re: Leaking gaskets need diagnosed (with pics)
    start the engine already lol
    as it runs the rad will drop, just keep topping it off as you wait for the fans to come on. once the fans come on bleed it, then top off if needed, cap it off. your all done.
    you could be waiting like 15 minutes or longer for the fans to turn on. FYI.
  17. #197 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok. Good thing I have about 1/32 tank of gas. Lol no its just under 1/4. I started it up, no leaks
  18. #198 Re: Leaking gaskets need diagnosed (with pics)
    sounds good.
  19. #199 Re: Leaking gaskets need diagnosed (with pics)
    Congrats!
    I'm away for one day ...and you've finished up etc. That's awesome. On burping the cooling system. I've found that the bleed screw is nothing more than a sick joke for GM engineers to get our clean engines coated in coolant.
    I let it run for a bit.. turn it off, let it run for a bit..turn off. The start/stopping will help burp.
  20. #200 Re: Leaking gaskets need diagnosed (with pics)
    It happens, when I did my vc gaskets I forgot to put the elbows back in and had to tear it apart again. That job took like 6 hours
    Sent from the Milky Way
    Did you discover it before or after the coolant started pouring out? hahahaha
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
