Thread: This is why you go with a roller timing chain.
Results 1 to 13 of 13
  1. #1 This is why you go with a roller timing chain.
    Banned
    CT
    XP cam, 105# springs, stock chain after 5,000 miles.
    XP Cam, 105# springs, stock chain after 8,000 miles.
    XP cam, 105# springs... Single roller after 40,000 miles.
    Don't base important decisions regarding your engine on conjecture.
    You're welcome!
  2. #2 Re: This is why you go with a roller timing chain.
    Oct 2011
    Puyallup WA
    Lol
    08 G8 GT - exhaust Tune
  3. #3 Re: This is why you go with a roller timing chain.
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    so what did u upgrade too
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: This is why you go with a roller timing chain.
    Banned
    CT
    Double roller.
  5. #5 Re: This is why you go with a roller timing chain.
    How many miles on the engine?
    Just curious what condition the engine was in before the cam was put in.
  6. #6 Re: This is why you go with a roller timing chain.
    Banned
    CT
    17,000 miles when the first one went in with the cam.
  7. #7 Re: This is why you go with a roller timing chain.
    The Boss Iceman6669's Avatar
    Jun 2011
    I feel there are other factors at play here... I personally know a few people running cams with stock style chains that have far more miles on them then that.
    Shawn Mayes even got 20k out of his dampener with a "stock" chain with 130\90 spring setup.
    2011 F-150 Yote powered
  8. #8 Re: This is why you go with a roller timing chain.
    Banned
    CT
    Well you can play roulette with your engine or just get good parts to start with.
  9. #9 Re: This is why you go with a roller timing chain.
    Apr 2011
    Vassar, Mi
    I shattered a damper and wiped out the CAS magnet in 5k miles with a roll master single on l92 springs
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  10. #10 Re: This is why you go with a roller timing chain.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I thought you didnt need a damper with the single or double rollers? Or does running it just give you a little extra safety?
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  11. #11 Re: This is why you go with a roller timing chain.
    I'm at over 20k on stock chain and damper with 130# springs
  12. #12 Re: This is why you go with a roller timing chain.
    Nice pictures, I've been interested in this stuff for a while as I see many singles on higher than stock springs as well. I've had the pleasure of pulling about 10 or so modded motors and had the chance to see the dampeners on singles and doubles.
    Singles, I've seen them come out similar to the pics above and Anthony's mention of shattering a dampener and it wiping out a motor (last swap I did for a guy was a shattered and wiped out). Then you have the other side where the dampener looks great after 40K+ miles on the higher rate springs.
    Doubles, Ok as a community we have learned that the double roller is not intended for our US 3800, and that the chamfer can be corrected to fix this, as well as machining the cam gear. Let's throw on a milled oil pump cover for good measure as well. Oddly enough I see those milled covers, with the correct chamfer and machined cam gear motors still rubbing the pump cover a little.
    While the double is clearly stronger, I have reserve feelings when seeing even a well clearanced DR still rubbing the pump cover. My thought is.. this platform isn't the best one to mod.
    BTW, Title is interesting, do you mean double roller?
  13. #13 Re: This is why you go with a roller timing chain.
    hangover park IL
    the later aftermarket dampers/tensioners that are a solid drab grey without molding swirls tend to be more durable than the swirl dampers that chip apart along the striations...
    always run a new set oem/cloyes gears and chain
    a new chain on worn powdered metal gears has too much slack
    broke an oem chain with 105's on a VS...wasnt pretty
    double roller properly machined is bestest
    ~James~ Psychotic Gearhead
  1. double roller timing chain
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2013, 06:47 PM
  2. Duble roller timing chain removal?
    By Adam D in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2013, 08:29 PM
  3. Roller Master Double Timing Chain
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2012, 08:28 AM
  4. help me with a double roller timing chain
    By foursixer in forum General Tech Discussion
    Last Post: 12-20-2010, 12:20 PM
