Thread: Pebble fell in engine
Results 1 to 7 of 7
  1. #1 Pebble fell in engine
    Apr 2012
    Windsor
    Hey
    So after doing some light maintenance yesterday i was putting my engine cover back on and when i went to put the oil filler cap back on, a small pebble about 1-2mm fell into the engine. I looked around for it and could not find it and than i got called to work so i had to drive it. I was thinking of pulling the valve cover to look for it but i am not sure if it would even be near where it fell now. Should i worry about this or will the filter just grab it?
  2. #2 Re: Pebble fell in engine
    hangover park IL
    it will sit below the fill hole forever.
    ive pulled apart tons of motors and found bits of grass/grit n **** bellow the fill hole.
    its probably sitting right next to the head bolt hex or near a spring
    ~James~ Psychotic Gearhead
  3. #3 Re: Pebble fell in engine
    I wouldn't worry, like James..
    It's amazing what you find inside an engine.
  4. #4 Re: Pebble fell in engine
    Apr 2012
    Windsor
    Great
    I feel a lot better lol, I have been reading about similar circumstance on other forums and people are saying they need to do a complete tear down to find it. So its just going to lodge somewhere and sit? or will it come out next time i change the oil, it was pretty small,
  5. #5 Re: Pebble fell in engine
    I found grasshopper remains in my 97 when I tore that apart.
  6. #6 Re: Pebble fell in engine
    its not like it went in the TB. then you would be tearing it down.
    even if it went down the oil drain holes from the head to the oil pan it would just lay there in the pan.
  7. #7 Re: Pebble fell in engine
    Dec 2010
    ATL,Georgia
    ^ ya like Scotty said if it had fallen into the chambers thats a different story haha
    I found a tiny snail shell under my front valve cover when i top swapped years ago.. no joke lol
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  1. Part identification (fell off car while in motion)
    By dddkrazyeyez in forum Introductions/Noob Questions
    Last Post: 03-21-2013, 07:31 PM
  2. Rear view mirror fell off
    By Fahrenheit in forum General Tech Discussion
    Last Post: 07-11-2012, 08:40 AM
  3. '06 GP rear speaker sounds like it has a pebble rolling around in it.
    By bluegirl in forum Audio, Security & Visual Electronics
    Last Post: 05-28-2012, 10:12 AM
  4. Something fell off my car.. what is it? o_O
    By Paramedic in forum General Grand Prix Discussion
    Last Post: 04-30-2012, 12:26 PM
  5. Part of the resonator fell off, should i fix it?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 11:14 PM
