Im out of ideas then if you have cleared all the fuses. Hopefully someone else will pop in that has some other ideas.
Check to make sure the cable going from the cruise control module to the throttle linkage is connected. On my 97, this would often come unhooked because of the type of connection it is.
But now that I think about it, might be totally different than your 04.
Mine went out a while ago too and from what I've read it could be a number of possibilities (like about 20 or so), so I pretty much said screw it. The odd part is that it randomly started working again for me, so whatever. I'll try and find my original post cause there was a ton of things to check.
