Thread: Cruise control not enabling...
Results 1 to 11 of 11
  1. #1 Cruise control not enabling...
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    I just had the engine replaced in my car lately. I finally got it back yesterday and when i was driving down the highway, i couldn't enable the cruise control. Tried multiple times and it never once turned on. Anyone know what might be causing the problem? Simply a sensor unplugged maybe?
    Btw, the car is a 98 Grand prix GT.
  2. #2 Re: Cruise control not enabling...
    Barksdale AFB, LA
    Could be the module isn't plugged up, or that the cruise cable isn't connected to the throttle bracket. There is no "sensor" specifically for the cruise system.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Cruise control not enabling...
    Jul 2008
    BFE, Kentucky
    Where would i find the module or throttle bracket? Anyone got a pic?
  4. #4 Re: Cruise control not enabling...
    Barksdale AFB, LA
    Cruise module is a black box bolted to the driver's side strut tower. There will be a cable that comes out, wraps around, and goes to the throttle body.
  5. #5 Re: Cruise control not enabling...
    Jul 2008
    BFE, Kentucky
    Alright, i think i know what you're talkin bout. Hopefully i can figure out what the problem is. Will update if i get it fixed :P
  6. #6 Re: Cruise control not enabling...
    Oklahoma
    Also, the third brake light being burnt out I believe will also disable cruise control.
  7. #7 Re: Cruise control not enabling...
    Barksdale AFB, LA
    Weird. Must be a GP quirk. That or it never happens on Impalas since our center brake lights are LED strips that never burn out.
  8. #8 Re: Cruise control not enabling...
    GXP Level Member
    Theworld
    My buddy's cruise control is not working, 1 of his 3rd brake lights are out.
    On my GTP, Both of my 3rd brake lights are out and my cruise still works fine..
  9. #9 Re: Cruise control not enabling...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I believe if the brake switch fails, it'll disable Cruise Control, too.
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: Cruise control not enabling...
    Jul 2008
    BFE, Kentucky
    Cruise is fixed. Woot.
    There were 2 cables coming from the cruise control module to the throttle body. The one closest to the front of the car was connected but the 2nd one was not. The cable fit right onto a little knob in the throttle body. Simple problem, simple fix.
    Thanks for the help, particularly sabrewings.
  11. #11 Re: Cruise control not enabling...
    Barksdale AFB, LA
    Should only be one cable going to the throttle body from the cruise module. The other cable to the throttle body comes from the gas pedal.
    Either way, glad you got it fixed. I figured it was something stupid like that since you said the engine was just replaced.
  1. Woodward Dream Cruise
    By GOINDEF in forum Shows and Events
    Last Post: 08-16-2008, 11:10 PM
  2. Vernon Texas Cruise
    By Red_GTP in forum Southwest
    Last Post: 08-07-2008, 07:34 AM
  3. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
  4. Cruise Control Light
    By Darkcelle in forum Off Topic Discussion
    Last Post: 06-12-2008, 06:13 AM
  5. Replies: 14
    Last Post: 02-10-2008, 12:37 PM
