Thread: False Alarms
Results 1 to 8 of 8
RichCresci False Alarms 10-07-2008, 12:46 PM
speedemongtp Re: False Alarms 10-07-2008, 01:22 PM
justwhisen Re: False Alarms 10-07-2008, 03:54 PM
gtpinsc Re: False Alarms 10-08-2008, 04:38 AM
whiteknuckle Re: False Alarms 12-11-2008, 01:06 PM
bronzegp Re: False Alarms 12-10-2008, 01:31 PM
SyntheticShield Re: False Alarms 12-10-2008, 01:33 PM
DanGTP Re: False Alarms 12-10-2008, 02:10 PM
  1. #1 False Alarms
    SE Level Member RichCresci's Avatar
    Jul 2008
    ok, so, last night at about 3 am my alarm went off. Its never done that before. I have set it off by bumping into it, closing my hood, reaching in an open window and hitting unlock, it even goes off in bad thunderstorms, But last night nothing happened. Did someone try to break in?
  2. #2 Re: False Alarms
    Ohio
    I have the same problem not sure what causes it. At one of my friends houses if i park out front my alarm randomly goes off for no reason not sure what causes it. It will do it in the middle of the day middle of the night doesnt matter just randomly throughout the time its parked there it goes off. Possibly cause i have the sensitivity all the way up but even then it should have some sort of reason to go off an when i run out an look theres no one around nothing at all no cars nothing. So your not the only one that has this problem i would like to know what causes it as well.
    00 GTP demodded and forsale
  3. #3 Re: False Alarms
    Jul 2008
    Poteau Oklahoma
    if I am not mistaken they are opperated by a rf signal. lots of stuff uses rf, remotes(tvs, celing fans, garage door, etc. could be someone from a block or so over.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: False Alarms
    Jul 2008
    sumter,south carolina
    it was a ninja....he was too quick for u to see
    02 GTP with mods 05 GP for DD
  5. #5 Re: False Alarms
    Moore,OK
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  6. #6 Re: False Alarms
    Dec 2008
    Michigan
    So what can you do about it...cause my '00 gp gt does the same. It will just randomly go off (4) chirps then stop.
  7. #7 Re: False Alarms
    Oklahoma
    Moved to the correct area.
  8. #8 Re: False Alarms
    Feb 2008
    Mine used to do the same thing. I think it was a neighbor's cat jumping up on the car or something. I even tried to set the sensors at the lowest sensitivity, but the alarm would still go off at almost exactly 2am. I finally got tired of waking up when it went off, so I turned the alarm off completely. I haven't felt like messing with it since then.
  1. Major false KR on 2000 Malibu 3100
    By Zef_66 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-15-2008, 01:52 PM
  2. False low coolant indication
    By sfrance in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-09-2008, 05:25 AM
