Thread: Idle voltage....Alternator?
Results 1 to 20 of 24
Threaded View
  1. #1 Idle voltage....Alternator?
    Jul 2008
    nj
    I have been keeping an eye on my voltage ever since I changed my tensioner 2 weeks ago. I noticed while the trans is engaged the voltage drops to just above 12v. I increase my rpms to see if that would help. As of right now I am idling at 750rpms. As soon as I hit the gas it goes up to 13.8 and slowly climbs to mid 14s. The volts are 14.6 when I cruise and 15volts at cold start up. I do have a electric water pump and an intercooler, but that should not be enough draw. I also have a stage 1 zzp alternator booster.
    What do you guys think this is pointing at? voltage regulator, alternator or is this normal? Just want to be prepared for the possible cost before I bring it to autozone for testing.
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. fuel pump voltage
    By theone2043 in forum General Tech Discussion
    Last Post: 11-10-2008, 01:35 PM
  2. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
  3. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
  4. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
