Im not so sure that is normal at idle. In order to charge, the alternator has to put out more voltage than the battery voltage of 12 volts. I dont recall ever seeing an alternator put out less than 13 volts at idle, normally its around 13.6 or so. With a voltage booster it should be putting out even more at idle.
I understand. But, There is no car in stock form that idles at 700 rpm's. I have a stage 2 voltage booster and still see right around that. No problems for over a year now. I'm sure if he would put the stock idle tables back he would be seeing the correct amount of voltage
