Thread: Idle voltage....Alternator?
Results 1 to 20 of 24
  1. #1 Re: Idle voltage....Alternator?
    Oklahoma
    Im not so sure that is normal at idle. In order to charge, the alternator has to put out more voltage than the battery voltage of 12 volts. I dont recall ever seeing an alternator put out less than 13 volts at idle, normally its around 13.6 or so. With a voltage booster it should be putting out even more at idle.
  2. #2 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    I understand. But, There is no car in stock form that idles at 700 rpm's. I have a stage 2 voltage booster and still see right around that. No problems for over a year now. I'm sure if he would put the stock idle tables back he would be seeing the correct amount of voltage
  3. #3 Re: Idle voltage....Alternator?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Dude, my car idles stock at 650RPM. Most 3800s I've come across idle at ~700 +/-50 depending on the weather and cleanliness of the IAC.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Ok then you tell us what the problem is.
  5. #5 Re: Idle voltage....Alternator?
    Barksdale AFB, LA
    Faulty voltage regulator in the alternator or faulty alternator. It's simply having trouble maintaining voltage at idle. My car can maintain up to 15+ volts if the battery is low at 650-700RPMs idle. If it isn't giving you problems while driving, then it really isn't a big deal.
    Though, I've seen this be a prelude to an alternator that just gives out. Can't say exactly when or even if. But it's possible.
  6. #6 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    I was off on my accusation of the idle speed. And agree with you on your above statement. But for the record mine does the same thing....untill around 900 rpm's then it jumps to around 14. something
  7. #7 Re: Idle voltage....Alternator?
    Barksdale AFB, LA
    You kinda had me wondering. Usually people raise their idle with a cam, not lower it.
  8. #8 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    True
  1. fuel pump voltage
    By theone2043 in forum General Tech Discussion
    Last Post: 11-10-2008, 01:35 PM
  2. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
  3. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
  4. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
