Thread: Idle voltage....Alternator?
Results 1 to 20 of 24
  1. #1 Re: Idle voltage....Alternator?
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Ok then you tell us what the problem is.
    Faulty voltage regulator in the alternator or faulty alternator. It's simply having trouble maintaining voltage at idle. My car can maintain up to 15+ volts if the battery is low at 650-700RPMs idle. If it isn't giving you problems while driving, then it really isn't a big deal.
    Though, I've seen this be a prelude to an alternator that just gives out. Can't say exactly when or even if. But it's possible.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    I was off on my accusation of the idle speed. And agree with you on your above statement. But for the record mine does the same thing....untill around 900 rpm's then it jumps to around 14. something
  3. #3 Re: Idle voltage....Alternator?
    Barksdale AFB, LA
    You kinda had me wondering. Usually people raise their idle with a cam, not lower it.
  4. #4 Re: Idle voltage....Alternator?
    TDCRacing
    Guest
    True
  5. #5 Re: Idle voltage....Alternator?
    Before anything you should get yourself a good voltage gauge that plugs into the cigarette lighter, or a multimeter on the battery is best. The voltage gauges on the dash are a good indicator but never 100% accurate, often they can be out a fair bit.
  1. fuel pump voltage
    By theone2043 in forum General Tech Discussion
    Last Post: 11-10-2008, 01:35 PM
  2. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
  3. Alternator ????????
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 10-27-2008, 11:01 PM
  4. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
