View Poll Results: Culprit
Voters
1. You may not vote on this poll
  • CV Joint
    0 0%
  • Rack and Pinion
    0 0%
  • Tie Rods
    0 0%
  • Suspension
    1 100.00%
  • Transmission/Engine mount
    0 0%
  • Other (Please describe in post)
    0 0%
Thread: Clunking when turning far left to far right sitting idle. What do you think?
Results 1 to 19 of 19
  1. #1 Clunking when turning far left to far right sitting idle. What do you think?
    SE Level Member void33's Avatar
    Jan 2013
    Chicago
    2000 Grand Prix GT
    Okay so I would have posted this in the Suspension section but I'm not sure that is what it is.
    When I am driving or standing still (engine on or off) and I turn far right and then far left(or visa versa) there is a *CLUNK* *CLUNK* coming from the front end somewhere. It is decently loud.
    It seems if I turn far right, back to the middle, and then back right again(or visa versa) there is no *CLUNK*. I think this is because whatever is loose is already compressed to the right side due to the first far right turn.
    I replaced 2 outer and 1 inner tie-rod and both control arms roughly 15-25k miles ago with ACDelco parts so although that's still a possibility, I am not betting on it being either of those. I have also replaced both wheel bearings recently.
    Anyways, any help is greatly appreciated. I made this a poll so I could easily see what the overall consensus turns out to be.
  2. #2 Re: Clunking when turning far left to far right sitting idle. What do you think?
    more then likely its the tie rod ends.
    but you'll never know unless you jack up each wheel and check em out.
  3. #3 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    If the tie rods are loose enough to make that clunking noise would I be able to push them in and out by hand?
  4. #4 Re: Clunking when turning far left to far right sitting idle. What do you think?
    jack each front wheel up one by one. leave the lug nuts tight. then push and pull the tire via the 3 and 9 o clock areas. there should be no movement. if its clunking i bet they move a good 1/4 inch.
    you can change them yourself, but you'll need an alignment asap after you change them. do the pair aka both sides.
    and make sure you have a grease gun to grease the new ones.
  5. #5 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    I did those recently, they were pretty bad. I can't imagine they are bad again but I will give it a try tomorrow. Thanks for the quick reply
  6. #6 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Feb 2013
    37.295091, -121.930053
    Scotty scotty scotty why haven't you voted on the poll on here? Lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  7. #7 Re: Clunking when turning far left to far right sitting idle. What do you think?
    if those are new it could be the ball joints. to test them take the wheel off get a large screw driver or pry bar and wedge it by the ball joint and try to make it move.
    if they are bad enough when jacked up wheel lugs tight, if you pull and push the bottom of the tire it will move in and out.
    best to get new lower control arms, they come with a new ball joint and new bushings. dormans are about 40 a side.
  8. #8 Re: Clunking when turning far left to far right sitting idle. What do you think?
    St. Louis
    Have you checked both ends of the front swaybar? If it is cracked on one side or the other (which is common) I've heard a clunk/pop noise. Both my 00 GP GT and my buddies 02 Imp suffered from this and the sway was cracked on the drivers side on both cars. Also agree on checking the ball joints as Scotty stated.
  9. #9 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Dec 2013
    You may have a steering intermediate shaft making noise. It wasn't as big of issue in 2000 as it was in later years but could still be the problem. Typically you can take them out and lube them and all is well.
    Sent from my SCH-R970 using Tapatalk
  10. #10 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    Scotty, - I did replace the control arms about 10k miles ago so I don't think it is that but I will look today.
    FordMan, - How would I check if it is cracked? When it makes that noise is it a pretty loud clunk/pop noise?
    Daheazle, That would be the steering column right? Wouldn't there be play in the steering wheel then? I don't notice any play in the steering, how could I check this though?
  11. #11 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Dec 2013
    It is the piece that connects to column to the gear and passes through the body in a rubber boot. It has a slip joint on it that binds and causes the popping noise. It will not be loose at all. The are not real easy to diagnose. The best way is to put your hand on it when you turn the wheel and see if you can feel it. If you have the front wheels off the ground when your turn the wheel the noise will go away as there is no load on the steering system.
  12. #12 Re: Clunking when turning far left to far right sitting idle. What do you think?
    it would have helps a ton if you posted whats been changed already.
    what about the strut mounts? pop the hood rock the steering wheel back and fourth, if the centers of the strut mounts are moving back and fourth it could be that. maybe you can hear it and see it move.
  13. #13 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Dec 2013
    He did in the op....
  14. #14 Re: Clunking when turning far left to far right sitting idle. What do you think?
    but he put them all in the poll. i read poorly sometimes lol
  15. #15 Re: Clunking when turning far left to far right sitting idle. What do you think?
    St. Louis
    To check the swaybar, turn the wheel right to lock and then look behind the drivers side tire and the sway is visible. Then left to lock and check the pass. side. If it is cracked it will be around there the loop where the endlink goes through it. Right where the bar flattens out to make that loop is where they crack. I have the one off the Imp that I replaced still sitting outside if you want a close up pic of what to look for.
  16. #16 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    I think I found the problem. There is something rubbing against the aluminum vacuum/brake lines down near the rack and pinion. it pops them back and forth and since it is right in front of the driver seat it is very loud in the car. When the car is jacked up on the front end it is not as loud, probably because the tie rods are sitting a bit lower with the wheel fully extended. I will do more research and post again.
  17. #17 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    Okay so I got a few pictures of the problem. I ended up bending the vacuum/brake lines up a bit to be out of the way of the tie rod's boot. here are some pictures of before, when it was rubbing on the according and making a popping/clunking noise, maybe this will help someone down the road:
    Clunking when turning far left to far right sitting idle. What do you think? Attached Images
  18. #18 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Dec 2013
    None of the lines are in the bracket. Can you get them back i there? Also it kinda looks like they are dangerously close to the transmission
  19. #19 Re: Clunking when turning far left to far right sitting idle. What do you think?
    Jan 2013
    Chicago
    That's what I tried to do for a good 30 minutes then I realized they had been replaced about halfway down from the top of the engine and whoever replaced them didn't give it enough slack so they won't fit into the clips.
  1. Clunking in steering wheel when turning or in a turn...
    By rizer in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2013, 01:39 AM
  2. Clunking noise when turning wheel?
    By Hippo Machine in forum General Tech Discussion
    Last Post: 09-16-2012, 02:02 PM
  3. low speed clunking and creaking when turning....
    By twillroth in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2012, 09:16 AM
  4. *Clunking Noise From Front Left*
    By CleanGP in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2009, 01:12 PM
  5. Loud Clunking coming from rear left
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2008, 10:16 PM
