Thread: Rusty Fuel Filter YYYAAAHHH!
Results 1 to 15 of 15
  1. #1 Rusty Fuel Filter YYYAAAHHH!
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    Plain n Simple. Got a pretty rusty fuel filter. The threaded end doesn't budge. So I sprayed it pretty heavily with some WD40 and gonna
    let it sit overnight hoping to break threw the rust tomorrow. Any suggestions? Anything else I can do? Alternatives? Hit me.
    Top-Swapped GT, SLP headers, 3.2 Pulley, Stage 2 Intercooler
  2. #2 Re: Rusty Fuel Filter YYYAAAHHH!
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    subbing to this because when i rotated my tires i looked at my fuel filter and that thing just LOOKS 100% corroded including the lines.
    2001 Grand Prix GTP, silver w/ black hood, silver bullit 17s
  3. #3 Re: Rusty Fuel Filter YYYAAAHHH!
    Hold the nut on the line and spin the filter off.
  4. #4 Re: Rusty Fuel Filter YYYAAAHHH!
    Dec 2012
    Where 4T65E's were born
    Mine looked like this (not original) and I still had a hard time getting it off.
    You're going to need a flare nut wrench to get it off, no exceptions. Use it on the fuel line side on the right, and hold it still. Turning it will twist the whole line. Then put a wrench on the filter and pull like mad to try to get it off. On the filter only.
    Sold.
  5. #5 Re: Rusty Fuel Filter YYYAAAHHH!
    if you dont have a line wrench for the line nut, use vise grips tight as hell, dont turn the line nut, hold it where it is, then put another wrench on the filter's hex nut there, ( you se it in the pic up there) crank on the filter, while holding the line nut still. if the line nut turns, the line will twist, and well, then your fixing a broke fuel line.
  6. #6 Re: Rusty Fuel Filter YYYAAAHHH!
    Put vice grips on the nut that are as tight as Scottydoggs can make them. That's way past friggin tight btw. Unbolt the 10mm holding the filter bracket and get the bracket off it. Then spin the filter while the vice grips don't move.
    My car has 226K (yeah I'm catching you Scott) and it's likely never had a filter. Unless it was done before 64K miles ...cause that's how old the air filter was. I run it to nothing (actually ran out one day) all the time... she purrs.
  7. #7 Re: Rusty Fuel Filter YYYAAAHHH!
    my filter is ugly too, never been changed by me, 227,000 and its still running. ive never ran it out of gas yet. im sure ive been close tho lol
  8. #8 Re: Rusty Fuel Filter YYYAAAHHH!
    Tried the Vice grips method just now. Wont move. Line replacement?
  9. #9 Re: Rusty Fuel Filter YYYAAAHHH!
    Tried the Vice grips method just now and it wont move. Line replacement im guessing?
  10. #10 Re: Rusty Fuel Filter YYYAAAHHH!
    put your big boy pants on and crank on that filter till it breaks free, are you turning it the right way right? seen that before lol
  11. #11 Re: Rusty Fuel Filter YYYAAAHHH!
    LMAO! Big boy pants...Yea Im turning to the right. I tripled check to make sure I was. People are suggesting PB blaster...may get some of that
  12. #12 Re: Rusty Fuel Filter YYYAAAHHH!
    Pennsylvania
    Quote Originally Posted by rell2005 View Post
    Just wanna put this out there, WD-40 is a lubricant and a water displacer, and it'll probably dissolve rust, but it's not much of a penetrating oil... it wont do much for nuts and bolts that are rusted on as it wont get into the threads and such very well.
    Get either PB blaster or Liquid Wrench.
    ZZP actually had an article where they recorded how much torque was needed to remove a stuck bolt with various lubricants.. WD-40 was the hardest to remove... PB Blaster came in with low torque numbers, number 1 name brand was Kroil with Liquid Wrench almost at a tie. The winner however, was a home brew of ATF and acetone, lol.
    Edit: This article was posted on ZZP, but came out of Machinist’s Workshop magazine
    Sport Edition Kv5 18x8
  13. #13 Re: Rusty Fuel Filter YYYAAAHHH!
    wait! turning it to the right? thats not right, its left loosey, righty tighty.
    if your head is under the d/s of the car, looking up at the filter, hold the line nut still, pull the filter nut towards you aka away from the frame towards the under side of the car body.
  14. #14 Re: Rusty Fuel Filter YYYAAAHHH!
    Nov 2013
    Quote Originally Posted by FriboRage View Post
    I saw that too. It was a 50/50 mix of the two. Don't make too much at a time though -- the acetone evaporates real fast if not in a tightly sealed container. I just knew I saved that quart of Type F for a good reason.
  15. #15 Re: Rusty Fuel Filter YYYAAAHHH!
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Just did this a couple weeks ago...Broke the connection loose and the line nut was turning, I didn't realize it wasn't turning on the line, twisted the line right off. Dorman makes a repair kit. Cut the line with a tubing cutter back where it is straight, bend the new tube to match, and the kit comes with a compression fitting to join new/old lines so no flaring needed. was an easy fix but better to avoid it as Scotty says,
  1. Rusty Fuel Filter YYYAAAHHH!
    By rell2005 in forum General Grand Prix Discussion
    Last Post: 10-09-2013, 07:51 PM
  2. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
