Nick, the funny thing here is it's you that are the liar. I haven't said a thing about you that wasn't 100% true and accurate.
You've suggested you know about knock and you don't appear to...at all. There is no such thing as false knock, it's a myth and a ghost that some folks use to explain why they can't correct a knock issue.
"The PCM contains integrated Knock Sensor (KS) Diagnostic Circuitry. Input signals from the knock sensors are used to detect engine detonation, allowing the PCM to retard ignition control (IC) spark timing based on the amplitude and frequency of the KS signal being received. The knock sensors produce an AC signal under all engine operating conditions. The PCM calculates an average voltage of each knock sensor's signal and takes instantaneous signal voltage readings. The PCM uses the instantaneous signal voltage readings to determine the state of the Knock Sensor Circuitry. If the Knock Sensor System is operating normally, the PCM should monitor instantaneous KS signal voltage readings varying outside a voltage range above and below the calculated average voltage, as shown in the normal knock sensor figure."
Now that you've learned about the knock sensor a bit. It's time to google further. I am willing to provide proof or at learn further. Found very little backing up kr being induced at the shift. Although again there are quite a few guys speaking about it.
Jared (had a GT500 blower on his car)
http://idahoclub3800.com/viewtopic.p...b7d78c4b7dcc88
Not even much about it.
I've read quite a bit and found a few things that support the understanding I had and a few that contradict it. I am a stand up, honest guy, which is why I post this information. Reading up more in the FSM and ... would you believe it looks like you are wrong? Damn shame you won't post anything that proves it out.
