Thread: Thinking of converting to E85.. Yes or Ne??
Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 224
  1. #1 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    Car pulls strong for the mods.
    Can't wait to line him up with Ed's car.
  2. #2 Re: Thinking of converting to E85.. Yes or Ne??
    GTX Level Member crbquist's Avatar
    Massachusetts
    Quote Originally Posted by SnowFlake View Post
    I second that
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  3. #3 Re: Thinking of converting to E85.. Yes or Ne??
    In the late 90's it was 14ft lbs. I have never looked up anything over a 2000, and doubt it changed.
    On the knock settings, please do the reading on HPT or DHP sites (if it's up) about it. There's pro's and con's as well as some info that guides you to what folks have tried and liked/had issues with etc.
    On the KR at the shift point, there's even more settings on various things relating to torque management etc. GM in the programming injected knock at the shifts to reduce power and be nice to the trans. That may be your shift kr that you see. Even something as simple as calculated torque/power can upset the tune if the tune hasn't been setup properly.
  4. #4 Re: Thinking of converting to E85.. Yes or Ne??
    in my tune i had to move these thresholds way out and once that was done my car never knocked again. once it's beyond what the max thresholds are set the PCM doesn't like it at all.
  5. #5 Re: Thinking of converting to E85.. Yes or Ne??
    Where is the whp #?? Then we could look at the timing vs boost vs fuel type vs whp produced.
    Still missing pieces of the puzzle here.........
  6. #6 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    There is no such thing as programmed KR at the shifts.
  7. #7 Re: Thinking of converting to E85.. Yes or Ne??
    According to you. Thanks for your input on it.
  8. #8 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    No problem, just ensuring that the correct information is disseminated.
  9. #9 Re: Thinking of converting to E85.. Yes or Ne??
    It's a shame your ego is larger than your base of knowledge
    That's induced as KR BTW.
  10. #10 Re: Thinking of converting to E85.. Yes or Ne??
    Feb 2009
    flintnasty MI
    I have never found this. All of my transmission tuning shows directly in timing, not with any KR in all 97, 98, 99-01.5 and 01.5-03 code bases.
  11. #11 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    There is no such thing as KR programmed by the PCM to reduce torque on shifts. The PCM retards timing independent of the knock detection system.
    KR is a direct result of noise picked up by the knock sensors in a certain frequency range. There is only knock, and false knock... there is no "programmed knock" for torque management.
    You don't have to agree with me, you can just be wrong.
    The small blips that Chris is seeing (under 1*) are likely from noise being picked up somewhere else... not from actual knock/detonation.
    The characteristics of real knock are opposite that of false knock.
  12. #12 Re: Thinking of converting to E85.. Yes or Ne??
    LOL, I've admitted to being wrong etc many times. It's called being humble, when you learn it ... let us know. Til then you may want to consider browsing the FSM on the info you are speaking about. You can't find the term "False knock" in the manual, because false knock isn't a real item. It's a mechanical issue that needs to be fixed.
  13. #13 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    The KR I'll get at times is as soon as I mash the throttle and sometimes at shift point. Before my e85 conversion it did this with 93 as well. I'll get a blip of a degree or less then it immediately goes away. When nick and I were tuning yesterday, I was getting a degree right around 4600 rpm at wot and then it would immediately go away. This happened on two pulls. Today I did a couple wot pulls and got no KR at all, not one blip. Weird.....
  14. #14 Re: Thinking of converting to E85.. Yes or Ne??
    not weird... Grand Prix...
  15. #15 Re: Thinking of converting to E85.. Yes or Ne??
    Banned
    CT
    The m90 is kind of a *****.
    True story.
  16. #16 Re: Thinking of converting to E85.. Yes or Ne??
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I remember John and Brian from Intense telling me that they programed some torque management into my tune to protect the less than beefy stock trans. I do remember John telling me that power is lessened at the shift point to protect the trans. I thought it was reduced timing right before the shift point but I cant remember for sure... I can't wait until I get a Triple Edge trans and can tune again with a N* throttle body and ported blower... I wouldn't worry about a 2* or less blip of KR here and there
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  17. #17 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Quote Originally Posted by tms8582 View Post
    Ported gen 3 blower? If that's the case then just get a gen 5 dude...
  18. #18 Re: Thinking of converting to E85.. Yes or Ne??
    Washington Michigan
    Quote Originally Posted by crbquist View Post
    Why? A ported gen 3 is just as good as gen 5 from what I hear
  19. #19 Re: Thinking of converting to E85.. Yes or Ne??
    Massachusetts
    Well ya heard wrong! Haha. A stock gen 5 will still outflow and be more efficient than any fully ported gen 3.
  20. #20 Re: Thinking of converting to E85.. Yes or Ne??
    All of this makes me want to buy a DIY megasquirt kit more and more and do it that way fvck all the factory issues to work around........
  1. converting
    By cmn36 in forum General Tech Discussion
    Last Post: 01-15-2011, 07:18 PM
  2. converting a 01 to an 04
    By sasquatch094 in forum General Tech Discussion
    Last Post: 03-25-2010, 05:22 PM
  3. Converting to supercharged
    By Bechtel88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2010, 09:31 AM
  4. question on converting.
    By gt42lst in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2009, 11:54 AM
  5. Converting from a 1 bar to a 2 bar map.
    By TurboKent in forum General Tech Discussion
    Last Post: 03-16-2008, 02:10 PM
