lift the two colored tabs up, then push the plug on the injector, then push the clip back in.
I don't think you understant the level of my incompetence. When I took them off, instead of following your directions, I pulled the tab up, then used a screwdriver like a lever to pop the connector off instead of pushing the button. I now have three connectors that the tab is broken and won't click in. I found a replacement on line. only 4 dollars each, but now a few more days wait.
