Thread: DIY Lower intake manifold gasket replacement with picutes and questions
Results 1 to 20 of 66
  1. #1 Re: DIY Lower intake manifold gasket replacement with picutes and questions
    Akron, Ohio
    Thank you. I can now rest easy. I was about to lift the car and look under.
    As far as replacing the conectors, you can just pop off the end and put on another. It takes a special tool, but not a long process. If you look at the connector there are the two opening where it connects adn two others below it. Put a small pick or tool in the bottom hole and the wire pops out. The things I have learned inthe past by breaking things I never should have.
    Any special tips prior to restart? Just turn the key and let it rest for a minute until fuel pressure builds up and then crank? Going to change oil after runs a bit incase anything got in there.
    Oh, and the leaking coolant elbows over time leaked onto the power wteering lines and they are rusted and need replaced. Got a quote for $1000 to replace both from the dealer.
  2. #2 Re: DIY Lower intake manifold gasket replacement with picutes and questions
    Quote Originally Posted by dgjks6 View Post
    dont let the dealer change the lines, they are easy to change.
  1. how do i know if my lower intake manifold gasket is bad?
    By asite57 in forum General Tech Discussion
    Last Post: 05-08-2012, 07:03 AM
  2. 3400 ohv lower intake manifold gasket questions
    By Bjorn20 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-13-2012, 07:34 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. the best lower intake manifold gasket?
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 05:04 PM
  5. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
