take the vac lines off. leave that boost solenoid in place there. leave its vac line to the top of the sc. you can leave the TB on and T stat housing as well if you like.
being you are taking your time and are in no rush, head out to advance auto and pick up some new vac T's and all new vac line, should be about 5 to 6 bucks. they sell a 2 pack of small white t's for 2 bucks, work perfect.
oh, take the alt the rest of the way off. and this is also a good time to change both coolant elbows. you can upgrade to the metal elbows.
