Before I do any more modding , I need to figure out an annoying little issue.. From a stop, there seems to be a big lack of power, as I cant even break the tires loose, as it feels like its bogging.. Then when not going any certain speed, I give it 1/2-3/4 throttle and it downshift, it will accel real slow, then kind of "open up" .. Like its bogging, then opens up and moves much quicker, then bogs again for a second then starts pulling hard again.. I hope that made sense.. So Im gonna try some cleaning of the system and see if that helps
So
First thing is a new fuel filter: Will anyone do OK? Im against anything from FRAM so any suggestions from anything from , NAPA, Advance, Orielly AZ etc?
Then I would like to dump some seafoam into the brake booster line.. Ive never done this before, but am sure there is a certain way to do it.
Then after that was done and I go thru a tank of gas, I was going to check the Fuel Pressure at the rail.. So what psi should it be, with Key on, car off... And car running
Also any other ideas ,, or if you need a better explanation to my issue, please just let me know , Thanks
Matt
