Thread: Lower ball joint leak
Results 1 to 6 of 6
  1. #1 Lower ball joint leak
    Jul 2013
    Ontario
    So my drivers side lower ball joint went so I replaced it and a few days later there was grease all over my rim it was coming out of the bottom of the ball joint ( not around the rubber at all) so I took it off sent it back they sent me a new one I put it in and what do you know does the same thing leaks out the bottom in the same exact area, can anyone help? Should I go somewhere else for a ball joint? Is this common? Thanks in advance
  2. #2 Re: Lower ball joint leak
    Get a dorman control arm instead.
    Here in the states they are 42 a pop, in canada likely more, but atleast the ball joints are good quality and you get new bushings aswell.
  3. #3 Re: Lower ball joint leak
    Jul 2013
    Ontario
    So that comes with ball joint attached? Thanks for the reply
  4. #4 Re: Lower ball joint leak
    Mar 2012
    South Beloit, IL
    I second this. Just installed my Dorman arms two days ago, they work very well.
  5. #5 Re: Lower ball joint leak
    Nov 2011
    NY
    Energy suspension sells replacement boots... Just sayin...
  6. #6 Re: Lower ball joint leak
    Jul 2013
    Ontario
    Thanks for the help! I just ordered me a dorman control arm was $96 here.
  1. Ball joint help
    By geetee in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2011, 05:23 PM
  2. ball joint maybe?
    By Jakegday in forum General Tech Discussion
    Last Post: 10-04-2009, 11:15 AM
  3. Ball joint?
    By kissmyss in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 04:59 PM
  4. Ball joint-What do ya think?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-25-2008, 11:32 AM
