Sorry, Car is a 06 GT
Sounds good on the filter
I just planned on pulling the booster line of, "semi" closing the line with my thumb and using a pour cup to pour it in the line.. Ill google it in a second put Im guessing once you pour all the seafoam in there, you just let it run for a few more seconds then turn off the car, put the line back on and let it sit for 10 minutes or so?
Ill check on the rail pressure as well.. I thought it was 44 also, while running
I have 605s ready to go in, but will need some good wires. I have ( on my 2000 ssei ) just bought the blue NAPA belden lifetime wires.. Nothing fancy, and look thinner than stock but have heard they are pretty descent.. ANy other suggestions? I would like a black wire if possible, just for future cosmetic reasons
I cleaned the TB last November iI believe, but will do it again
LIM gaskets.. Its an 06, so I believe they dont have the crap gaskets, that the earlier models do.. But it is a possibility . If it came to that point, I would probably just add new 1.8 rockers and 90# springs as well
I WOULD cut/gut the cat, but dont want to throw a code.. I ordered a Overkill PCM a few days ago, with the rear o2 delete, because I 'planned' on doing headers, but not sure atm..
